Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 20, 2006
Old     (tripleup)      Join Date: Apr 2004       12-04-2006, 5:45 PM Reply
Where are the drain plugs to drain the block on an indmar monsoon?
Old     (jon_a)      Join Date: Feb 2003       12-04-2006, 6:15 PM Reply
you have two brass plugs (sometimes can be knock sensors) on either side of the middle of the block. They should be pretty obvious when you look at your block. If you are winterizing, Remember to drain your manifolds, thermostat housing hose, and your raw water pump housing and take out your impeller.
(Message edited by Jon A on December 04, 2006)
Old     (batman)      Join Date: Nov 2001       12-04-2006, 6:51 PM Reply
Also if you have ballast pumps, they need a blowout!
Old     (cbrown)      Join Date: Jan 2004       12-04-2006, 9:28 PM Reply
Alex you have one knock sensor and one drain plug on your motor. Other than that follow what jon said and you will be set.
Old     (lake_side)      Join Date: Jan 2004       12-07-2006, 12:41 PM Reply
Why do you take out your impeller.
Old     (jon_a)      Join Date: Feb 2003       12-07-2006, 1:48 PM Reply
It will dry rot.
