you have two brass plugs (sometimes can be knock sensors) on either side of the middle of the block. They should be pretty obvious when you look at your block. If you are winterizing, Remember to drain your manifolds, thermostat housing hose, and your raw water pump housing and take out your impeller. (Message edited by Jon A on December 04, 2006)
