Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 20, 2006
Old     (john_prine)      Join Date: Nov 2006       12-03-2006, 12:00 PM Reply
I was wondering if anyone knows the Tourqe and Horsepower curve of these two engines? Which engine will eat more gas while boarding and Cruising around? Overall, which Engine will be a better buy for a Wakesetter 23LSV?
Old     (cbrown)      Join Date: Jan 2004       12-03-2006, 2:05 PM Reply
In my opinion the 8.1 is the best motor for the 23 and up boats. Wakeboarding the motor will use similar fuel as the monsoon. When you open it up is where the 8.1 uses more gas. But I feel that the benefits of the 8.1 justify the fuel usage.
Old     (john_prine)      Join Date: Nov 2006       12-03-2006, 6:33 PM Reply
yep
Old     (xaggie)      Join Date: Nov 2002       12-03-2006, 7:20 PM Reply
For sure +1 on the 8.1
Old     (bennygoodx)      Join Date: Aug 2006       12-03-2006, 7:45 PM Reply
I love my 8.1
Old     (hyperlitenrd)      Join Date: Jan 2003       12-03-2006, 8:31 PM Reply
we have a monsoon in our lsv, and complaints. We get about 4gph with stock ballast and people.
Old     (johnny_jr)      Join Date: Mar 2006       12-04-2006, 9:59 AM Reply
8.1 all the way, I went with the Monsoon and regret it.
Old    formulacb            12-04-2006, 10:04 AM Reply
There's no replacement for Cubic Inches when it comes to powering a boat.
Old     (tuneman)      Join Date: Mar 2002       12-04-2006, 10:48 AM Reply
Every wakeboard boat should come stock with a big block.(Unless you cruise more than you ride. But who does that?) The 8.1 will use less fuel in the long run because it doesn't have to work as hard to get up to speed and maintain it.
Old     (eubanks01)      Join Date: Jun 2001       12-04-2006, 11:27 AM Reply
Hyperlitenerd - Do you guys use the wedge? With it I feel we get much worse fuel consumption than 4gph. Without it the wake is pretty small IMO.
Old     (kevin_lsv23)      Join Date: Oct 2006       12-04-2006, 1:12 PM Reply
I have the 340 5.7 engine in a 2007 23lsv. Plenty of power for the stock ballast and wedge, however, I would love to get 4 gph with wedge up, let alone down. That said, I have never owned a big block car or truck that got better mileage than a small block. A bigger, heavier, engine will add a few expensive pounds of ballast, but it is not going to get better mileage. If your ego needs a big block, go for it. Otherwise the only justification would be if you are planning on running a lot of extra ballast, and need the power.
Old     (john_prine)      Join Date: Nov 2006       12-04-2006, 1:19 PM Reply
Well if you think you dont get better mileage with the 8.1 then run the same weight you are running but run it with the 8.1 and check your consumption. Like dude said above, if you cruise all day it doesnt make sense to get the 8.1. If you ever have a bunch of people in the boat and you are running stock Ballast and wedge down, it does make sense. You will have to power the motor up more to get the power you need which then leads to higher RMS. Just my opinion but if you like the small block and it floats your boat, then go with it.
Old     (ralph)      Join Date: Apr 2002       12-04-2006, 2:10 PM Reply
The difference in cost between the big block and small block buys a LOT of gas. And no I don't think all the difference in capital cost is recovered on resale.
Old     (hyperlitenrd)      Join Date: Jan 2003       12-04-2006, 3:15 PM Reply
Eubanks,
My friend uses the wedge, I do not. we do use it for wakesurfing, but then we are using a little more than 8gph ;)
We have never had a problem with power with stock ballast and 9 people. And we run stock ballast and another 700 in water ballast for surfing. So unless you are running 3k in ballast with people at altitude, I couldnt justify the 8.1.
(Message edited by hyperlitenrd on December 04, 2006)
Old     (xaggie)      Join Date: Nov 2002       12-04-2006, 10:15 PM Reply
It's the same point as towing with a diesel pickup. I may never need to tow 19,000 lbs but I suppose I could with my F-350. I might not make ALL my money back when I sell the damn thing (or use less fuel), but I sure do know it's there if for some reason I should need it. I like not having to worry about putting 10+ people on my boat and going boarding with ballast. The boat could care less. Could I deal with the MCX? Yea of course but my 8.1 is like my diesel. The piece of mind is worth the price to me. My father told me a man can never have too much sex, cash, or horsepower and i'll stick with that.
Old     (john_prine)      Join Date: Nov 2006       12-05-2006, 12:56 AM Reply
I Agree
Old     (john_prine)      Join Date: Nov 2006       12-05-2006, 12:34 PM Reply
HAHa
