Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 26, 2006
Old    Taylor (bigwaken2009)      Join Date: Oct 2006       10-18-2006, 6:40 PM Reply
I have everything pretty much figured out except for the fact of how to pump water using the preexisitng hole in the boat??? HELP
Old    Lil Tuna (rmack)      Join Date: Jul 2005       10-18-2006, 7:39 PM Reply
Drill new holes. I should post the pictures of my ballast install. I have three ballast puppies connected to three intakes. Two I drilled new, one was existing. Pretty easy
Old    Stan Tanner (sbt3)      Join Date: Jun 2002       10-19-2006, 6:46 AM Reply
if you don't want to drill you can Tee into your fresh water intake line. I have 3 simer pumps running off of my intake and can fill all 3 while driving full speed without starving the engine of water. I have had them installed for 2 years and haven't had a single problem.
Old    Nacho (denverd1)      Join Date: May 2004       10-19-2006, 7:15 AM Reply
drill it
Old    Rich (rich_g)      Join Date: May 2003       10-19-2006, 8:48 AM Reply
you need some basic plumbing parts to draw water thru the center drain fitting. Use bronze / brass fittings, not PVC
Get a short piece with male threads on each end to go into the 1" opening, a 90 degree piece, then a bronze shut-off valve. After that connect to your tubing, pumps, whatever, but you need the shut-off valve for safety. Use teflon plumbers tape on all fittings.
Old    Paul (phat_in_cincy)      Join Date: May 2003       10-19-2006, 10:11 AM Reply
You could drill or add a manifold. I drilled. Each pump gets own thru hull. Here's my install: http://www.wakesiderides.com/forums/index.php?showtopic=17225
