Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 07, 2006
Old    Steve Jones (steve_jones)      Join Date: Jun 2006       09-30-2006, 7:10 PM Reply
I just moved to Colorado and I thought I would tackle this before the landscapers start. Has anyone dug out a pit for a trampoline before? If so, what did you use for drainage? How did you line it - or- keep the perimeter from falling in and eroding? And what did you put in the bottom? Any help would be great. Thanks in advance.
Old    358army            09-30-2006, 7:30 PM Reply
just make sure you dig it deep enough... reckon you shouldnt have to worry bout puttin a liner in. the water should just get sucked into the ground. as for the perimeter just dont make it to big so everybody is walking near it.... and this is that im assuming your digging the hole on/in the lawn...
Old     (attila916)      Join Date: Oct 2005       09-30-2006, 7:41 PM Reply
Hey Steve, I think that is a great idea! I would love to see the finished product.
Old    Mike Isler (isler)      Join Date: Apr 2003       09-30-2006, 7:49 PM Reply
Yup, we had one for our rectangular trampoline. It was lined with mulch on the bottom, and 2x12's used for the sides (attached to 4x4's). Drainage was a bit of a problem... we lived on the lake, and the bottom of the trampoline pit was probably only a foot or so above the water table. After a big rain, it would gather a foot or so of water in the pit, and would take several days to drain out.
Keep in mind airflow... when you jump on the trampoline, it will compress the air underneath. On the rectangular trampoline, there was no padding over the corners so air would rush in and out through those holes. Just something to keep in mind.
Old    Rod (rvh3)      Join Date: Jul 2003       09-30-2006, 8:08 PM Reply
Steve,
We have a round pit for 14' tramp that is concreted . It has a sump in the middle with a submersible sump pump that is plumbed to the yard drainage. Check with your insurance company about permanent trampolines. We had to cheat to even acquire home insurance. If you'd like pics, let me know and I'll take some for you.
Old    Ken (ghostrider_2)      Join Date: Aug 2004       10-01-2006, 12:23 AM Reply
rod would you post them for the rest of us?
Old    Gordon M (gmarkham1)      Join Date: Sep 2003       10-01-2006, 6:14 AM Reply
here is a pretty good resource on this subject, I received more detail directions from them via email, but I guess I deleted it somewhere along the line..
http://www.webounce.com/In-Grnd/
Old    Chris Weber (cweb)      Join Date: Sep 2006       10-01-2006, 8:50 AM Reply
we have a rectangular trampoline dug out about halfway. i would recoment doing it that way, so you can get underneath it if you need to.
Old    Rod (rvh3)      Join Date: Jul 2003       10-01-2006, 9:28 AM Reply
I'll get some pics posted by tonight.
Old    Rod (rvh3)      Join Date: Jul 2003       10-01-2006, 12:54 PM Reply
Old    Rod (rvh3)      Join Date: Jul 2003       10-01-2006, 12:57 PM Reply
As you can see, it can get a bit of algae underneath. I go under about twice a year with hose and shop-vac and get it clean.
Old    Rod (rvh3)      Join Date: Jul 2003       10-01-2006, 12:58 PM Reply
Oh, and today wasn't one of those days. NFL takes precedence.
Old    Steve Jones (steve_jones)      Join Date: Jun 2006       10-01-2006, 6:51 PM Reply
Thanks for posting the pics and the links guys. I've narrowed down the construction to one of a couple methods. I have also downloaded a pdf file with one method if anyone wants it.
Method 1: Much the same as Rod's set up. Dig hole, build retaining wall of some sort, allow for drainage.
Method 2: Dig hole in a pattern similar to a coffee filter or upside down pyramid. The hole is gradually deeper as you approach the center, and not so deep (except the legs)on the perimeter.
I'm leaning toward a retaining wall version with gravel or mulch in the bottom, with drainage to the main back yard channel. We'll see.
Thanks again for the help guys. True Wakeworld sharing!! This saved me some time.
Old    Kraig Kaiser (kraig)      Join Date: Dec 2002       10-01-2006, 8:40 PM Reply
Steve- I live in Colorado as well. I've built a few trampoline pits in the industry I'm in. If you're looking for some good "Colorado" ways of doing it drop me an email. It's something I can have done for ya as well. MileHighWakeboarder@msn.com
Old    Mateo (wkbrdr)      Join Date: Jan 2006       10-01-2006, 8:41 PM Reply
thats tight...if u had the money put some stone and tile...for drainage...
Old    Jared (jaredb900rr)      Join Date: Aug 2006       10-02-2006, 11:49 PM Reply
Whut's up Mr. Steve Jones? It's Jared from Utah! Long time no talk man. So, you moved to Colorado, huh? Tis the season (well, almost)!
I've done a number of in-ground tramp pits over the last 3 years. They can be done relatively cheap using plywood around the legs of the tramp forming an octagon with 4-6' stakes on the inside of the plywood so the wood doesn't cave in, 2x4s screwed along the top sides of the plywood and then treated 2x6s resting on top of the 2x4's and plywood to give it a clean finished look.
We use a few inches of 3/4" crushed gravel along side the walls of the plywood to allow for drainage and to keep the plywood from rotting. We also use 3-6" of gravel on the bottom to keep a clean look. Feel free to do something with drainage as long as you can slope it away from the tramp.
I can walk you through it if those instructions were a lil rough.
Jared
Old    Peter_C (peter_c)      Join Date: Sep 2001       10-03-2006, 12:22 AM Reply
Steve, curious as to why you moved to Colorado? That is a beautiful place to be :-)
Old    Steve Jones (steve_jones)      Join Date: Jun 2006       10-03-2006, 10:50 AM Reply
Thanks for the post Jared. I like that idea. The instructions are a little fuzzy but I'll PM you if I get lost. (And yes, very long time no talk.)
Peter, I'll PM you but in short; Sarah transferred with her firm, I hate Sierra Cement, and I'm over driving in the Bay Area. The lake situation blows out here but I'll get into a private lake by next spring....or build one.
