Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 29, 2006
Old    bt211            08-24-2006, 2:10 PM Reply
What is the amount of weight that a 2000 SAN ballast come with. A boat we are looking at has two ballast compartments in the back. There is no bow ballast. Is this much of a problem. And when did they start putting the bow ballast in the SAN? Thanks
Old     (mike_gilbert)      Join Date: Sep 2004       08-24-2006, 2:13 PM Reply
520lbs, san has never offered bow ballast, if you mean belly ballast it was in 2002 i believe offered on TE. Its better if it doesnt have the center tank, it takes up the whole locker and only weighs 300 lbs, put a big 700 sack in there.
(Message edited by mike_gilbert on August 24, 2006)
Old     (solo)      Join Date: Oct 2001       08-24-2006, 3:49 PM Reply
SAN's require 500 pounds in the nose or the wake will be really steep. Get a sack.
Old     (seattle)      Join Date: Mar 2002       08-24-2006, 3:56 PM Reply
I put a Fly High Pro X 400lb bag in the locker, it fits perfect without any pinch points when completely full. The back hard tanks are 250lbs each. I added 600lbs of lead. 300lbs in the bow under the seat cushions, 100lbs under either back seat, and 200lbs on the floor in the back.
Nothing but compliments on the wake.
