Old    Sam Aikele (atropine)      Join Date: Aug 2004       08-24-2006, 8:06 AM Reply
I need a little clarification about the Malibu Ballast systems. In reference to a 2004 23 LSV, I was told that they came standard with a 3-tank system (center, 2 rear) and could be upgraded to a 4-tank "MLS" system at the time of ordering, that adds the bow tank. Is this true? If so, does the 3-tank system use 3 pumps, and the 4-tank system 4 pumps?
Thanks
Old    Eubanks (eubanks01)      Join Date: Jun 2001       08-24-2006, 8:40 AM Reply
Yes on all accounts. My question would be how are you ordering a boat that is almost 3 years old?
Old    Chad (chadbp)      Join Date: Oct 2005       08-24-2006, 9:05 AM Reply
I'm pretty sure there are actually two pumps per tank, Malibu doesn't use reversible pumps. So one is used to pump in and one pumps out.
Chad
Old    Sam Aikele (atropine)      Join Date: Aug 2004       08-24-2006, 9:46 AM Reply
Thanks for the info guys. I'm not ordering a new boat, but I was talking to a guy who owns a 2004 and I think he was confused my what ballast system he has. I just wanted to make sure I understood the Malibu system correctly.
Old    WakeDoc (riverrunner)      Join Date: Aug 2006       08-24-2006, 10:44 AM Reply
Malibu uses 2 pumps per tank, one fill, one drain
Full MLS is front, mid and a rear tank on each side
Old    Small Light (stephan)      Join Date: Nov 2002       08-24-2006, 11:07 AM Reply
I thought bow tanks didn't come in 'til '05? Is that just the VLX and no the LSV?
Old    Eubanks (eubanks01)      Join Date: Jun 2001       08-24-2006, 11:43 AM Reply
Sorry Sam, I meant to clarify that each tank has 2 pumps.
Heavy - The LSV got a new hull in 2004 with the bow tank. The bow tank wasn't available on the VLX until it got the new hull (same as LSV) in 2005.
Old    Larry (larrys)      Join Date: Jun 2005       08-24-2006, 12:41 PM Reply
Sam, some of the 04's with 4 tanks had only 3 switches from the factory. One switch for each rear tank and one switch that controlled both the mid and bow tank. This is how mine was until I added a 4th switch. Not all 04's were this way.
Old    Sam Aikele (atropine)      Join Date: Aug 2004       08-24-2006, 2:21 PM Reply
Larry-
That probably explains it. He only has 3 switches, but clearly has a bow tank.
Thanks
Old    ilovetrains            08-25-2006, 9:23 AM Reply
The bow tank was an option on the 04, but is standard on 05 and up. Even though it only has one switch for center and bow, it most likely has spearate motors and can be re-wired as Larry did.
