Old     (paolad)      Join Date: Aug 2005       08-21-2006, 9:59 AM Reply
So I thought something was wrong with my water pump adapter, so i replaced it. Still didnt work on either of my cigarette lighters on my boat. Tested it from my car and it works. Sooo did my cigarette lighters on my boat mess up? Do I just replace the fuse? If so, where are they commonly found? I have an 05 Centurion.
Old     (big_xstar)      Join Date: Nov 2004       08-21-2006, 10:28 AM Reply
more then likely the fuse, Wish i could tell you were the fuses were on your boat.
Been to San v lately???
Old     (fish6942)      Join Date: Dec 2005       08-21-2006, 10:43 AM Reply
On my '05 Centurion the fuse panel is under the dash. The fuses are all very well marked.
Old     (sammm724centurion)      Join Date: Aug 2006       08-21-2006, 11:15 AM Reply
My fuse blew when we pumped up our tube. They are like less than 25 cents. You can get a pack of them at Home Depot for like a couple of bucks. The fuses on your boat should be under the dash, easy to find. Always keep extra so in case one blows. You don't want to be on the water all day with no stereo.
Old     (talltigeguy)      Join Date: Sep 2003       08-21-2006, 11:34 AM Reply
On a Tige, they are also under the dash. I blew one once as well.
Old     (paolad)      Join Date: Aug 2005       08-21-2006, 1:52 PM Reply
Thanks alot everyone. I will make a run to Home Depot.
Hey There Kevin, been going to Mission Bay the last few weekends and getting the course there. Fun but hate the extra boat cleanup.
Old     (rodmcinnis)      Join Date: Sep 2002       08-22-2006, 10:10 AM Reply
Paola:
Before you run to Home Depot take a look under the dash and figure out what you need.
A lot of boats use circuit breakers instead of fuses. The push button types are the most common, if it has popped the button will be sticking out, just push it back in.
At the very least you need to know what type of fuse and the amperage.
Old     (loux2)      Join Date: May 2004       08-22-2006, 3:12 PM Reply
I had the same problem. It took a while but I finally figured out my 4 year old son had put a nickle in the cigarette lighter. I have the push button circuit breaker and I must have reset that thing like 100 times before I looked in there and saw that nickle.
Old     (paolad)      Join Date: Aug 2005       08-23-2006, 10:51 AM Reply
Thanks All. I looked under the dash and used the fuse for the shower I dont have to test it and yup the fuse for the cigarette lighter was bad. Yeah!!! Finally a simple fix and inexpensive!!!
