Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       08-21-2006, 9:53 AM Reply
My front bag is leaking pretty bad. I repaired it once but the leak is back. It's leaking on the bag side around the fitting. It seems impossible to repair as you have to tear in to the bag to re-seal it from the inside. I put a bead of silicone around the outside last time. It held for about a month. Anyone have an ideas? I called Fly High to ask them, they said ship it back to us and we'll have a look and see what we can do.
Old    Lucky275 (lcky275)      Join Date: Jul 2002       08-21-2006, 10:00 AM Reply
have you tried PVC cement? I sealed all of my fittings with it, and no leaks
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       08-21-2006, 10:23 AM Reply
Nope haevn't tried that yet. I guess it's worth a shot. I used that on my rear bags b/c the fittings themselves were leaking ( I used it on the threads to lock them together). This has nothing to do with the threads, its outside of the fitting. The bag fittign has some sort fo nylon flap that is sealed to the inside of the bag, this is what is leaking. I'll try the cement.
Old    Peter_C (peter_c)      Join Date: Sep 2001       08-21-2006, 10:48 AM Reply
Why not ship it back and see, not only if they can repair it, but there is a good chance they might just replace it.
Edit: or offer you a deep discount on a replacement.
(Message edited by Peter_C on August 21, 2006)
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       08-21-2006, 12:38 PM Reply
Here are two pictures of where the leak is . you cna see I tired sealing it with silicone (whiteish) but it's leaking from the same spot.
Old    Lucky275 (lcky275)      Join Date: Jul 2002       08-21-2006, 12:55 PM Reply
I don't think PVC cement will work outside the fitting. It actually melts the fittings together. I misunderstood your 1st post, and I think it'll make it worse it you try the cement.
Old    Karl De Looff (boarditup)      Join Date: Jan 2004       08-21-2006, 1:48 PM Reply
PVC Cement is what is needed to repair it. Get some PVC fabric from an awning vendor for reinforcement. The material is from inflatable boats, so that kit will work as well.
Old    Kvkev (kvkev)      Join Date: Oct 2003       08-21-2006, 6:31 PM Reply
I've got a oem front sack I'll sell you from my 03 Supra. Email Kevhale@aol.com
Old    David (tparider)      Join Date: Aug 2003       08-21-2006, 6:44 PM Reply
get a new one. Or switch out with one of the rear ones you have. Or email the guy above for a used one.
