Old     (acurtis_ttu)      Join Date: May 2004       08-14-2006, 9:35 AM Reply
I have an 04 22SSV, and my rear (drain)pump went out. Due to the space, lack of, I need to find the exact replacement. It's model # 203f (700gph) anyone ever replaced this before? I couldn't find it online anywhere.
Old    buttskimmer            08-14-2006, 11:09 AM Reply
I got one my desk with your name on it
Old     (bull)      Join Date: Jul 2006       08-14-2006, 9:33 PM Reply
Hey adam it wasn't a fuse was it? My '03 ssv went out the other day and it turned out to be a 7.5a fuse in the block under the dash. Figure you already checked that but I'd hope it didn't cash on you already.
Old     (stanfield)      Join Date: Mar 2004       08-15-2006, 6:06 AM Reply
I had the passenger side rear drain pump crack on me to where it started leaking. It looks like a super tight fit, but there's actually a bit of room to work with once you get down there. I was in a hurry that day to get it fixed and back on the water so I cruised by Boaters World which only had a 550gph pump that had similar demensions. It's an easy fix with a hack saw and screw driver.
I still haven't replaced it with the correct pump so that sack always drains slower. What can I say, I'm ghetto like that.
Old     (acurtis_ttu)      Join Date: May 2004       08-15-2006, 6:31 AM Reply
Ryan, checked the fuses and according to the volmeter I'm still getting power back at the pump. the pump will actually kick on for a second or so if you beat on it with a screwdriver, then it clicks off. It is definately going out.
