Old     (wiscxstar)      Join Date: Mar 2002       08-01-2006, 9:14 AM Reply
The rear bag on the port side of the boat fills by itself. It fills when the boat is underway or if any of the other bags are filling. I have checked the soleniod valve and it is in the correct position, any other ideas? Also my ballast pump system filter leaks ( a steady drip) is this normal or should I put some teflon tape or something similar on the threads?
Thanks!
Old     (bradstang)      Join Date: Feb 2004       08-01-2006, 1:14 PM Reply
Your value is not operating properly, check the switch located on the value for that sac. Otherwise your value need to be cleaned since it must be open. I had the same problem and the switch on the value was in the open position.
(Message edited by bradstang on August 01, 2006)
Old     (heem)      Join Date: Dec 2005       08-01-2006, 2:58 PM Reply
I have the same problem as well. Was told to check the manual switch on the valve, which is fine. Open to other opinions.
I'll check my value as well, is that next to the oscillating warbilator?
Old     (billthom)      Join Date: Apr 2005       08-01-2006, 3:20 PM Reply
I assume you guys all talking about the same valve as this post:
http://supramoombariders.com/web/forums/32/ShowPost.aspx
The post above was my problem when I had it...
Old     (wiscxstar)      Join Date: Mar 2002       08-01-2006, 6:38 PM Reply
Brad- do mean "valve", because I am not sure what "value" is unless you mean the position of the switch on the valve...?
Bill- yeah that is the same valve, but what Jim G and I are saying is that we have already checked the switch and it is in the correct position, but the bag still fills... I am going to take it apart and see what happens, but I have feeling I am going to have to replace that valve :-(
