Old    patrick (kookhead4581)      Join Date: Nov 2005       07-28-2006, 12:13 PM Reply
so far inflatable boats are the cheapest boats i can find below $500. reason why i went with inflatables because of its portability. question is what type of motor, boat size, and hp do i need to run at least 25-30 mph? i just need it to generate enough speed to shred and bust air up to 2-3'.
Old    bigrich            07-28-2006, 12:37 PM Reply
Sorry have no intention of bursting (no pun intended) your bubble. I don't think you are going to find anything with a motor on it for that money. Also I don't think inflatable boats put any wake at all for shredding and busting air.
I seriously hope this is a joke but if you are serious you might want to look at an older jet ski or something of that sort.
Old    Jeff Moore (jeff359)      Join Date: Jun 2005       07-28-2006, 12:48 PM Reply
"shredding and busting air"
Dude I gotta rad thing called a Skurfer for you to try. New wakeboards are wack
Old    Trace (trace)      Join Date: Feb 2002       07-28-2006, 12:56 PM Reply
I've heard this hog throws a nice wake.
Old    Jeff Moore (jeff359)      Join Date: Jun 2005       07-28-2006, 1:29 PM Reply
You might be able to upgrade for a few hundred more
You'd be able to "shred and bust air" hella good
(Message edited by jeff359 on July 28, 2006)
Old    bigrich            07-28-2006, 2:04 PM Reply
Jeff why you gotta dis' the skurfer. I still rock my skurfer for a good laugh. I think it would work better behind that yellow tri-hull though.
Old    Jeff Moore (jeff359)      Join Date: Jun 2005       07-28-2006, 2:24 PM Reply
Rich, you got the day glow body glove wet suit to go with it?
And you are right, a skurfer is much cooler than wakeboarding behind an inflatable, and almost as cool as the yellow tri hull.
Old    Rod McInnis (rodmcinnis)      Join Date: Sep 2002       07-28-2006, 2:35 PM Reply
Exactly what does it mean to "shred and bust air"?
I have a 10' inflatable with a hard bottom and a 9.9 HP outboard that will do 22 MPH. I actually use it to pull wakeboarders past the slider.
Video of it is here:
The boat is somewhat portable: Take the motor off and two guys can lift it on top of a large SUV.
I think you will be pretty hard pressed to find a useable inflatable and motor for under $500. A package like that new would be around $5000.
You can often pick up some 20 year old Jet Skiis for under $500, including a trailer!
Old    bigrich            07-28-2006, 2:36 PM Reply
Actually its too hot for a wet suit here. But I have been known to throw on the zebra striped banana hammock.
Old    bocephus            07-28-2006, 3:14 PM Reply
They have them here all the time:
