Old    Preston Hall (phall925)      Join Date: Feb 2005       07-27-2006, 8:08 PM Reply
Ok so I am going to install my ballast system in my 99 Xstar and I am going to put the thru-hulls just below the rub rail for the vent/emty lines. what type of sealing product do I need to use to ensure a good seal. I know this is a basic question but I just wanted to know and I knwo that they are above the water line but I do not want water seaping from pray or anything into the boat from these areas.
Thanks in advance
Preston
Old    Trace (trace)      Join Date: Feb 2002       07-27-2006, 8:42 PM Reply
3M 5200 marine sealant. Make sure your thruhulls are above level with the highest you would ever want to fill the sacks.
Old    Nacho (denverd1)      Join Date: May 2004       07-28-2006, 6:54 AM Reply
If you can't find the 5200, any marine silicone-based sealant will work. i've used these below the water line as well
Old    TR (biz)      Join Date: Mar 2004       07-28-2006, 7:10 AM Reply
I would stay away from 5200, try 4200 as this allows for dissasembly and is easier to work with or even the 3M marine grade silicone would work. look here
http://multimedia.mmm.com/mws/mediawebserver.dyn?6666660Zjcf6lVs6EVs66SY6HCOrrrr Q-
