read this post maybe... Initiating Scarecrow...I can't! I tried to explain the frontroll as best I could. If you dont already, hold onto the handle with both hands until at least 3/4s through the rotation. Whenever I used to come up short on the rotation, it would be because I dropped my back hand early. Not sure why, but it solved the problem for me. As for slack, I don't know. Is it tight until you get in the air? If it slackens up once youre in the air, maybe youre tugging on the line?? That would loosen it up. If you can explain what youre doing a little more detailed, I may be able to help some.
