Old    David Polk (smackus)      Join Date: Apr 2004       07-24-2006, 3:51 PM Reply
I need a replacement ballast bladder (the cover is fine) for my factory plumbed X-9. It is the bag under the rear bench seat. I can get it from MC but it is big $. I know somebody else makes them or can make them. It has three inlet/outlet elbow connector fittings for the quick connectors. I also need a section of the flex hose from the pump to the bag. Any ideas would be appreciated.
Old    C.I.E. J-Rod (jarrod)      Join Date: May 2003       07-24-2006, 5:09 PM Reply
Barefoot International
Fly High Pro X
Old    C.I.E. J-Rod (jarrod)      Join Date: May 2003       07-24-2006, 5:10 PM Reply
The Pro x are heavy duty coverless. But, that's who makes the sacks, and the quick disconnect fittings
Old    David Polk (smackus)      Join Date: Apr 2004       07-24-2006, 5:35 PM Reply
I saw those. My only concern is I have two fittings on one side high on the bag end and one on the other end low. It didn't look like the Pro X where the same setup. They have one on top and the others match. Will it still work the same. I also saw that they can custom make the bags. Do I need that or is the standard bag the same?
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       07-25-2006, 7:24 AM Reply
the custom fly high sacs are pretty expensive. soudns liek your trying to save some coin. If so just find the closest size bag yu can , it will be muhc cheaper. Fly high sacs have three openings, a fill/drain/vent.
Old    David Polk (smackus)      Join Date: Apr 2004       07-25-2006, 11:00 AM Reply
Thanks thats what I am getting.
