On HSBS 180s i think of having 3 options: 1)Land wrapped (the easiet trick to land wrapped, and probably best way to learn wrapped landings) 2)Pass early (when I pass early, I like to pass really low, under the butt even. this gives you time to grab after the pass) 3)Pass late (just about when landing. it isnt as important to pass low when you pass late because you wont have to worry about getting pulled off axis. If you pass late, grab early, you can hold a grab almost the whole way through if you pass late enough) -Steve
