Old    Charles (chas)      Join Date: Feb 2002       07-21-2006, 2:15 PM Reply
Have PerfectPass on the boat and was wondering where every one has there kdw and nn set at. I can get it close but still seams to surge a lil more than it should.
Boat: 06 20SSV with about 1500lbs
Thanks
Old    Spidey (amonteroman)      Join Date: Aug 2005       07-21-2006, 2:29 PM Reply
06 21V....KDW=180, NN=80, no surging at all.
Old    Charles (chas)      Join Date: Feb 2002       07-21-2006, 2:31 PM Reply
Thanks, I think mine is close to that. I might have to check my cable also.
Old    Gordon (rake)      Join Date: Jun 2003       07-21-2006, 3:58 PM Reply
Charles,
Make sure there is no gap between the brass servo cable connection and the throttle linkage when the boat is in neutral. The PP troubleshooting guide points to that as the main cause of surging.
Good Luck
Old    Team Neptunes (audiopro74)      Join Date: Jun 2005       07-21-2006, 6:52 PM Reply
You know.......... The sanger didn't surge at all
Old    Steve Winn (scheersound)      Join Date: Feb 2003       07-21-2006, 7:29 PM Reply
Do 06 boats have servo motors? I thought it was replaced with flyby wire or something. I have the same problem with my 06 211 with 2255 lbs of ballast.
Old    Steve Winn (scheersound)      Join Date: Feb 2003       07-21-2006, 9:43 PM Reply
I meant drive by wire.
Old    Charles (chas)      Join Date: Feb 2002       07-21-2006, 10:10 PM Reply
I hope to get out tomorrow and play with it some more.One corner of the engine cover is resting on the cable so i am going to fix that. Hope it helps.
