jarret, i saw that you can do hs bs in the flats and inside to out. i would be hammering this trick hard if i were you. youre almost there. slow the boat down a couple of mph. and try these from outside to inside(passing the handle is much easier). obviously just try to get midway between the wakes. once your comfortable with these start to take them bigger and youll be w2w in no time. also for the hs fs 3. empty the ballast out of your boat and slow down to about 15-16mph(emptying the ballast will clean up the wake). practice the trick going from inside the wake to outside. the falls wont hurt a bit, i promise. i learned them this way then started doing them from outside to inside the slowly sped the boat up and added ballast until i was going w2w. i spend the entire winter just doing these and bs 180s. i probably threw a few hundred of these while learing the trick. however now i can spin the three off a roller, a wake, ollie, whatever. i feel like i own the trick. give it a go, the slow boat speed will help reduce the tension and make the spin easier.
