Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 21, 2006
Old    Clayton191 (clayton191)      Join Date: Apr 2006       07-20-2006, 10:43 AM Reply
My CD player controls on the back of the 'bu arent working anymore. I can see things on the display, aka Volume, Radio Station, etc, but the buttons dont work. This is on the transom and the driver controls! I've replaced the headunit with a comprable sony hu that has the same kind of setup - still no work.
This happened to anyone else? I would really like to be able to control the stereo from the transom once again! :-)
Old    bigrich            07-20-2006, 10:51 AM Reply
I have heard that when the transom remotes fail it affects the whole system/Might want to try unplugging it and see what happens.
Old    Craig (yosquire)      Join Date: Jun 2005       07-20-2006, 12:45 PM Reply
Yes, one plug partially unplugged will cause havok on the whole system. check all the connections for the remotes. I've experienced this problem.
Old    Clayton191 (clayton191)      Join Date: Apr 2006       07-20-2006, 1:17 PM Reply
Does anyone know the best way to get to the one attached on the transom?!
Old    KG (iagainsti)      Join Date: Apr 2004       07-20-2006, 1:46 PM Reply
You should be able to get to the back of it thru the rear compartment hatch. There also should be a y-spilter behind the HU.
Old    I hate winter (ccraftskierfan)      Join Date: Mar 2004       07-20-2006, 8:16 PM Reply
I had the same problem. Mine came unplugged from the head unit. It was the small RCA cable above the antenna connection (black in color, if I remember right). I used a mechanics mirror to make sure it was in the right hole.
