Old    gary harvin (gharvin)      Join Date: Oct 2005       07-17-2006, 1:48 PM Reply
yesterday while picking someone up at a public dock I hit a rock at a very low speed (barely in gear). I noticed at low speeds a vibration until you get on plane. Any insight will help, is this a quick cheap repair, or a long expensive repair?
Old    Marty McFly (mcfly)      Join Date: Jan 2002       07-17-2006, 2:14 PM Reply
The longer you run with a vibration, the more damage you can do to the attached v-drive unit and transmission. You probably dinged the prop, which will cause vibration, but if you hit the rock solid enough, you could have bent the strut. If the strut is bent, the shaft is bent.
Have it checked out before any more damage is done.
McFly
www.waterskiboatsdallas.com
Old    Mikeski (mikeski)      Join Date: Aug 2003       07-17-2006, 6:59 PM Reply
Change the prop., fixes the problem most of the time.
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       07-17-2006, 7:21 PM Reply
You can replace it or have it reconditioned for about one third the price of a new one. Or buy a new one and have it re-worked and kept as a spare.
