Old    Erwin (koetse)      Join Date: Jul 2006       07-14-2006, 3:18 AM Reply
Which boat is the best for wakeboarding when a tower is mounted and fat sacks are used.
Correct craft ski nautique
Year 1997
engine PCM 260 PK
Or a ski Nautique 196
yer 2000
Engine: CM GT40 Pro Boss EFI 310 PK (227 kW)
Old    Ryan (bremsen)      Join Date: Aug 2005       07-14-2006, 7:56 AM Reply
I'm pretty sure those are essentially the same boat save for graphics. If wakeboarding was your primary activity you would be better off with the sport/air nautique IMO.
Old    Erwin (koetse)      Join Date: Jul 2006       07-14-2006, 8:02 AM Reply
When a monster tower and weight is installed will it then produce a decent wake??
Old    Ryan (bremsen)      Join Date: Aug 2005       07-14-2006, 8:17 AM Reply
Honestly can't say from experience on that boat....only from what I've read/heard. I have ridden a late 90s sport/air and its wake is very nice.
You might want to ask over on planetnautique.com. There might be someone there that has boarded behind one.
HTH.
Old    Karl De Looff (boarditup)      Join Date: Jan 2004       07-14-2006, 8:56 AM Reply
With about 1,200 lbs the wake is good if you like a steep wake (SANTE 210 - like).
Old    eric fox (fox)      Join Date: Jul 2002       07-14-2006, 9:37 AM Reply
I have a 92...similar with a slightly different hull design. Karl is correct...with 1000# it will be decent. That weight will take up a lot of floor space though. A tower will help you eliminate some of the clutter, so that's a great idea. If you ski also, this might be a good option.
Old    Peter_C (peter_c)      Join Date: Sep 2001       07-14-2006, 9:46 AM Reply
If you can buy an open bow so you can easily throw a sack in the bow.
Old    Phatboypimp (phatboypimp)      Join Date: Apr 2005       07-14-2006, 10:13 AM Reply
I know this is unrelated to your question, but I will never own another closed bow boat.
Old    882001 (882001)      Join Date: Nov 2003       07-14-2006, 10:14 AM Reply
tsc hull= flat wake even weighted
Old    bocephus            07-14-2006, 10:45 AM Reply
That boat is a comp boat and has one of the best slalom wakes out there! It will not be good for wakeboard at all, unless you are only interested surface tricks.
Old    Luciano Grimblat (luchog)      Join Date: Jun 2002       07-14-2006, 2:14 PM Reply
we used to ride behind a 1995 CC ski nautique closed bow and the wake with 1200# was awesome.
You loose all floor space though
Old    Darrel F (95sn)      Join Date: Sep 2005       07-14-2006, 2:37 PM Reply
1997+ is a tsc hull, CC's "premier slalom boat". Wake for boarding will be disappointing.
Old    Michael Baugh (kystyle)      Join Date: Aug 2005       07-14-2006, 2:46 PM Reply
If you use enough wieght and distribute it properly, you should be able to get a fun wake with either one of those boats. It probably won't be great, but sufficient for recreational wakeboarding. If you are serious about wakeboarding I would get an older model Sport Nautique or Super Sport.
Old    wakerida (wakekidd263)      Join Date: Jul 2006       07-20-2006, 10:53 AM Reply
thos boats are the exact same and are both made for skiing my buddie has one and teh wake is very small to wakeboard ide go with 02 sante
