Old    acase_14            07-18-2006, 1:44 PM Reply
when over speeds of 25ish mph, in rough water and when turning sharp my nvs tyrants "pop" what could this be from?
Old    Ian Koch (ian30)      Join Date: Jan 2005       07-18-2006, 1:48 PM Reply
I would say you have a bad connection somewhere, or a wire is shorting. Could be a bad amp too, but less likely.
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       07-18-2006, 1:50 PM Reply
definately has the symptoms of a wire/connection being loose, whether it's internal (amp/speaker) or external might be hard to tell.
Old    acase_14            07-18-2006, 3:04 PM Reply
so if it is wiring how would i find where the connection is bad?
Old    KG (iagainsti)      Join Date: Apr 2004       07-18-2006, 3:32 PM Reply
check the tightness of all power connections and grounds and possibly clean the terminals. Do your RCA's run along any power cables ? Also could be a bad connection behind the HU. Intermitten stereo issues are biaatch to track down so good luck !
Old    noah_d            07-18-2006, 3:46 PM Reply
maybe you shouldnt powerturn
Old    acase_14            07-18-2006, 4:48 PM Reply
k thanks everyone ill give it a shot (except for Noahs idea)
Old    noah_d            07-19-2006, 10:34 AM Reply
just giving you a hard time, i just dont ever remember making a sharp turn at 25 unless a rider was in danger or to avoid a object...just thought it was funny thats all. sorry
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       07-19-2006, 10:41 AM Reply
Noah brought up a good point, how often do you turn sharp going over 25 in a ski boat?
