Old    Ronia (ladythump)      Join Date: Jul 2004       07-02-2006, 9:14 PM Reply
I have a 4 channel amp that I am going to use to power 4 out of the 6 speakers in the boat. I have a 10" inch sub with a mono amp. I have two speakers on the tower with a two channel amp. My question: I want to wire the speakers to the head unit so I can have the boat speakers on FRONT and tower speakers on BACK fades. How do I do this when I have only have Front/Back/Sub RCA's on the back of my headunit???
Old    Robb Davis (boarder_x)      Join Date: Mar 2006       07-02-2006, 9:35 PM Reply
put front output to the amp powering the tower. put the back to the amp powering the boat, and the sub, to the amp powering the sub.
Old    Ronia (ladythump)      Join Date: Jul 2004       07-02-2006, 11:09 PM Reply
But there are two sets of RCA cables coming off of my 4 channel amp powering the boat.
Old    Robb Davis (boarder_x)      Join Date: Mar 2006       07-02-2006, 11:11 PM Reply
That's ok. Only use one set.
Old    Ronia (ladythump)      Join Date: Jul 2004       07-03-2006, 8:14 AM Reply
then why are there two sets?
Old    Robb Davis (boarder_x)      Join Date: Mar 2006       07-03-2006, 8:17 AM Reply
It's a 4 channel amp. It has the ability to take the two front, and the two rear. However, you only want to use one of those sets, so only hook up one set. The amp doesn't know that the four speakers it's powering are all front speakers.
Old    Ronia (ladythump)      Join Date: Jul 2004       07-03-2006, 8:49 AM Reply
So how should I wire the four speakers to the amp?
Old    Clubmyke (clubmyke)      Join Date: Aug 2004       07-03-2006, 11:54 AM Reply
do the amps have rca "outputs" ?
Old    Ronia (ladythump)      Join Date: Jul 2004       07-03-2006, 12:01 PM Reply
Yes. The amps have RCA outputs.
I think I understand what Robb was saying, You only need one RCA to the headunit as far as the amp is concerned, however if you want the headunit to run your speakers front to back off the amp, then you need two sets of RCA's.
Am I understanding that correctly??
Old    Robb Davis (boarder_x)      Join Date: Mar 2006       07-03-2006, 5:42 PM Reply
Yes, that's correct. Just use the one set of inputs, and all 4 outputs. Your amp doesn't care, it will just send all it's data to the "front" speakers.
Old    Ronia (ladythump)      Join Date: Jul 2004       07-03-2006, 5:46 PM Reply
Great! Thanks Robb
