Old     (newty)      Join Date: May 2005       06-22-2006, 7:23 PM Reply
95 Malibu echelon runs 5 mins and dies, starts back up runs 5 min and dies again. Has factory computer with auto kill after 5 min but only at an idle. Its doing it at cruising speed as well.
Any ideas?
Old     (newty)      Join Date: May 2005       06-22-2006, 8:57 PM Reply
Don't everyone post at once!
Old     (yosquire)      Join Date: Jun 2005       06-22-2006, 9:05 PM Reply
How does the ECU sense and determine idle? It sounds as though the computer believes the boat is always idling.
Perhaps it uses the neutral safety switch to determine "idle". Try starting the boat in gear - though not a 100% certainty test, if it did start, it'd tell you the neutral safety switch is stuck.
Old     (boss210)      Join Date: Jun 2006       06-22-2006, 9:38 PM Reply
FUEL PUMP OR ING COIL..
Old     (newty)      Join Date: May 2005       06-22-2006, 9:46 PM Reply
Thanks guys. I'm actually at work and my buddy called with the problem. I'll be towing him in when I get off work @ 600 am and we'll look at those things.
Old     (trace)      Join Date: Feb 2002       06-23-2006, 2:37 PM Reply
check and clean the fuel pickup screen in the tank too.
Old     (yosquire)      Join Date: Jun 2005       06-24-2006, 7:37 AM Reply
So your buddy had to wait from 7:20pm to 6am to get a tow in?
I'm confused, why didn't he just drive the boat back to the launch? It runs for 5 minutes at a time, correct?
Old     (ccraftskierfan)      Join Date: Mar 2004       06-25-2006, 3:43 PM Reply
Did this happen the first time out after winterization? If so, fogging oil can cause havoc sometimes.
