Old     (hemihauler)      Join Date: Jan 2006       06-22-2006, 9:47 AM Reply
Was at oroville for two days and on the second day the speedometer stopped working. Are their any things that I can do or check to try to fix it. Or is this a take it to the shop problem. Boat is a 2004 Cal air pro V, any help would be great.
Old     (rodmcinnis)      Join Date: Sep 2002       06-22-2006, 10:53 AM Reply
Is it the old fashion Pitot tube speedometer, or a paddle wheel electronic type?
If it is the pitot tube style then the odd are the you clogged the pitot tube. This happens a lot when there is debris floating in the water.
The pitot tube should look something like this:
This would be bolted to the transom of the boat, bow of the bow facing left in this picture. The leg that hangs down would have a small hole in the front side. If it is clogged you will often have luck picking the debris out of it with a needle or similar sharp pointy object. Just don't mess up the opening.
Sometimes the speedometer quits working because you hit something and completely knocked the pitot tube off. They do have a limited "kick up" capability so you may find that it has simply been knocked out of position.
Old     (hemihauler)      Join Date: Jan 2006       06-22-2006, 11:00 AM Reply
It s the old pitot tube kind I will try cleaning out the tub and see if this helps. Thanks for the help.
