Old    Nelly (gnelson)      Join Date: Jun 2003       06-19-2006, 11:11 PM Reply
It seems that in order to get a sweet surf wake you need to sac the crap out of your boat. So what if you have different riders in your crew (goofy and reg.). Is there a product out there or has anyone made something that can be easily shifted or moved from one side of the boat to the other.
Old    Show (bigshow)      Join Date: Feb 2005       06-20-2006, 10:36 AM Reply
What do you mean by easy?
I have 270 lbs of pop bags and I have 80 lb of bar bell weights that I mount on the tower. I switch between regular and goofy all the time - it's a real work out. Then I empty one aft lock and fill the other.
Old    4sher            06-20-2006, 2:44 PM Reply
We just make eveyone ride on the regular side. The funny thing is, it's my boat but I'm the only goofy rider. 3 years ago we got tired of moving the weight. It did forced me to learn how to ride back side. Then I learned how to ride switch.
Old    Scott Taylor (taylormade)      Join Date: Jun 2001       06-20-2006, 7:05 PM Reply
I put the lead in 1.5 gallon gas containers that way I can just slide them back and forth between the sides depending on what side you want to surf. I have removed the hard tanks and replaced them with 750# sacks, so all I have to do is just flip two switches (one to empty, one to fill) and slide over the 400 lbs of lead I have in the gas containers and we're all set.
Old    Nelly (gnelson)      Join Date: Jun 2003       06-20-2006, 10:17 PM Reply
taylormade-about how much weight is in one gas can and where do you get the lead.
bigshow-where do you get the pop bags?
taylormade-about how much weight is in one gas can and where do you get the lead?
Old    Show (bigshow)      Join Date: Feb 2005       06-21-2006, 7:06 AM Reply
Homemade Bags and foam from Lowes - metal from a scrap pallet at work.
Old    Scott Taylor (taylormade)      Join Date: Jun 2001       06-21-2006, 9:41 AM Reply
One 1.5 gallon gas container holds right around 60lbs. I bought the lead shot off a dude on ebay. GREAT guy and will bargain with you if you buy in bulk.
search lead shot. He sells them in 25lb increments, but I got 500lbs for $300 delivered.
