Old    Steve LeBlanc (leblanc1)      Join Date: Apr 2006       06-04-2006, 1:51 PM Reply
Just wondering if anybody has ever mounted these pumps some way to use as fill and drain pumps, as opposed to using them handheld.
Old    Steve LeBlanc (leblanc1)      Join Date: Apr 2006       06-04-2006, 1:52 PM Reply
PicUpload
Old    Troy (liveoz)      Join Date: May 2002       06-04-2006, 2:24 PM Reply
It is very common to use those pumps mounted. They were actually built originally as aerator pumps for bait tanks and were mounted. The cig lighter adapter is a mod. You will need two for each tank or bag that you want to fill and you can install them both on a 3 way rocker switch with one way turning on the fill pump and the other turning on the drain pump.
Old    Flux (flux)      Join Date: Jun 2003       06-04-2006, 2:47 PM Reply
My 02 SAN uses the Rule Aerator pumps. The system works well other than the obvious never enough weight thing. My only problem is that the fill and empty do all three, so no tweaking which is needed in that boat.
The system has seperate through hulls for each of the three fill pumps. There is a ball valve between each through hull and the aerator. It's pretty fast aside from the extra bags to fill, but we may replace the rear hard tanks with larger bags anyway. We also have a bag that sits on the bow seats.
The aerators are pretty reliable, no impellers, and are cheap to replace. Do like troy said if you go this route, use the rocker switches and you can tweak the rear sacks for a nicer wake.
Old    Steve LeBlanc (leblanc1)      Join Date: Apr 2006       06-05-2006, 2:01 PM Reply
Any thoughts or inputs on these pumps? Seems like a good price.
Attwood Tsunami Cartridge 1 1/8" Aerator Pump 1200 GPH ATT46607
ATT46607
Regular price: $46.53Sale price: $37.22
http://www.pleasureboatmarine.com/attsca11aepu.html
Old    Trace (trace)      Join Date: Feb 2002       06-05-2006, 2:49 PM Reply
I am in the middle of installing eight of the T-1200's in my boat. They're great pumps, but hard to find fittings for the oddball 1-1/8" threads.
Old    Dizzy Jenkins (dizzyj)      Join Date: Jul 2003       06-05-2006, 3:20 PM Reply
Trace,
did you find the fittings locally? i've been thinking of taping into my raw water and running a simple setup using the tsunamis.
Old    Trace (trace)      Join Date: Feb 2002       06-05-2006, 5:54 PM Reply
The pumps come with a 1" barb elbow, and I bought the rest from FlyHigh. They will also make custom fittings, but they aren't cheap. I had to get special fittings made to attach the pumps directly to the sack.
Old    Wes Gardner (wesgardner)      Join Date: Oct 2003       06-06-2006, 11:13 AM Reply
I used a short piece of 1 1/4" pvc hose between pump and 1" rigid pvc pipe into the manifold (hard to see in this pic)
Old    WAlove (masonwakerider)      Join Date: May 2003       06-07-2006, 8:33 PM Reply
If you like rule i'd go with the 2000gph aerator model # 207f not that much more expencive and twice as fast. Or you can get 3700 gph's from diversified marine with 1 1/2" in and out fittings. Thats about 500 gallons a minute. Thats just bad@ss
