Old    Chqwakeboarder (chqwakeboarder)      Join Date: May 2006       06-01-2006, 7:14 PM Reply
We are using Babe's Boot Butter (or somethin like it) and the binding blaster is not pumpin. I know the pump is on (by the sound) and there is nothin stuck in the line. So why isn't the thing workin? Peace
Old    Delta Force (wakebordr11)      Join Date: May 2001       06-01-2006, 8:30 PM Reply
is it primed? unfamiliar with the binding blaster but if you emptied it... it may not prime itself as pumping lube is a lil different than pumping/sucking water... in order to prime I guess ya gotta provide some suction to the outlet tube... just dont get any in your mouth hhaha
Old    John (nuts4water)      Join Date: Dec 2005       06-02-2006, 10:30 AM Reply
Most likely the seals are bad in the pump. I have had to replace my pumps twice in the last three years. The pump would pump water when I was trying to clean it out but it would not pump the soap.
Old    Chqwakeboarder (chqwakeboarder)      Join Date: May 2006       06-02-2006, 12:59 PM Reply
John, mine will also pump water, but not soap. So, I have to replace the pump?
Old    Jason Buffalow (buffalow)      Join Date: Apr 2002       06-02-2006, 1:13 PM Reply
Switch over to the Newt Shooter!
Old    Jason Buffalow (buffalow)      Join Date: Apr 2002       06-02-2006, 1:14 PM Reply
Switch to the Newt Shooter and no replacment pump necessary!
Old    C.I.E..... Evan (guido)      Join Date: Jul 2002       06-02-2006, 2:39 PM Reply
Better yet, get some CWB hingetech bindings and you'll never need lube again...
Sorry, hi-jack over.
Old    John (nuts4water)      Join Date: Dec 2005       06-02-2006, 5:11 PM Reply
Yup, the pump needs to be replaced. If your boat dealer is nice he may warranty the pump for you. Mine did!
