Old    Ryan E. (surfer_ryan223)      Join Date: Aug 2005       06-01-2006, 2:22 AM Reply
Can you put a perfect pass on a 85 mc prostar 190?? If so how hard is it to install?? Isnt the price like around 1000?? If I couldnt do the install how much would a dealership charge to put it in???
thanks in advance
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       06-01-2006, 6:22 AM Reply
yes it can be done, approx $1000 is correct, I've seen people charge from $200-$350 for install. Paddle wheel placement is critical, make sure they know what there doing.
Old    Mike (board218)      Join Date: Mar 2005       06-01-2006, 7:55 AM Reply
The install is pretty straightforward. The hardest part is placement of the paddle wheel as Adam indicated. It seems dealers in my area are getting about $400 to $500 for the install. I just installed mine and had a few problems. For instance, my hull is 1 1/4" thick so the paddle wheel housing did not fit properly and took some creative engineering to make it work. Also, my throttle arm was riveted on instead of being bolted on so it had to be grinded off in order to be able to bolt on the supplied one. So as long as you can handle little issues like that, it's no problem. Otherwise, have it installed.
Old    dhcomp (dhcomp)      Join Date: Jun 2003       06-05-2006, 5:26 PM Reply
Not sure how you are going to do it for $1000 in parts, the system is like $1500.....$1200 cost if you know a PP dealer.
But yes, you can put one on that boat.
Old    alan plotz (alanp)      Join Date: Apr 2001       06-05-2006, 6:22 PM Reply
the install is really easy and im not a very mechanically inclined person. if you have any issues you can call and speak directly to the designers/engineers and they will walk you thru any issues you may encounter.
