Old    Fill er up (fill_er_up)      Join Date: May 2006       05-30-2006, 5:38 PM Reply
I considered adding some kind of sound dampner to the removable panels on the sides of my v-drive and maybe on the bottom side of the middle sundeck hatch to reduce engine noise. Anyone done this and have ideas on what material to use?
Old    C.I.E. J-Rod (jarrod)      Join Date: May 2003       05-30-2006, 6:35 PM Reply
Hmm...sounds like a cool idea
Old    "G" (grant_west)      Join Date: Jun 2005       05-30-2006, 6:37 PM Reply
hey check out cascade audio. They make a bunch of sound dampners I.E hood blankets that would work great for this type of job
Old    Ken (ghostrider_2)      Join Date: Aug 2004       05-30-2006, 10:28 PM Reply
have you done it yet GRant? if not when are you..
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       05-31-2006, 7:14 AM Reply
west marine sells a kit for about $60 that you can do it yoruself.
Old    Brandon Key (souperfly)      Join Date: Apr 2006       05-31-2006, 7:57 AM Reply
The Malibu Crew has a complete DIY w/pics for a DD.
Old    Kevin McGuirk (ktmwakeboarder)      Join Date: Jun 2004       06-01-2006, 10:56 PM Reply
Could dynamat work?
Old    Ryan (bremsen)      Join Date: Aug 2005       06-02-2006, 6:05 AM Reply
Kevin, not really. Regular Dynamat is a deadener and reduces vibrations on whatever surface its applied to.....mainly for rattles and harmonics. You want an acoustical foam material with a heat barrier for this application.
Old    "G" (grant_west)      Join Date: Jun 2005       06-02-2006, 6:56 AM Reply
Ryan is right on. Cascade makes a few diffrent engine hood blankets that work in this exact same way
Old    Rod McInnis (rodmcinnis)      Join Date: Sep 2002       06-02-2006, 12:29 PM Reply
The good stuff is pretty expensive....,11640.html
This stuff has an inner core that is like a lead sheet, then has foam on either side. Note that it weighs a lot, one pound per square foot. It is very effective, however.
Take your time and get it glued on really well. Being so heavy it wants to pull off the walls so make sure the surface is clean before trying to stick it down.
Old    Kevin McGuirk (ktmwakeboarder)      Join Date: Jun 2004       06-02-2006, 10:29 PM Reply
nice nice, very informative and a good idea
Old    Nate (norcalmalibu)      Join Date: Jun 2004       06-02-2006, 11:54 PM Reply
I did this project a couple years ago, it has held fairly decent. The only thing that has fallen down is the heat reflective tape, it does not bond well with dampner. If I was to do it again I would just leave the seems a little crude showing the dampner. I used the spray on glue from 3m the strongest hold I think number 99.
