Old    Kvkev (kvkev)      Join Date: Oct 2003       05-26-2006, 5:42 PM Reply
Went from sputtering a week ago to will not even idle. It will fire for a few seconds and then dies. I've changed the fuel/water seperator, spark plugs,gas, distributor cap, rotor and coil. I see gas comming out of the throttle body injectors but it still will not idle or run. HELP
HELP
Old    Diggs (pdxWAKE) (tyler97217)      Join Date: Aug 2004       05-26-2006, 5:54 PM Reply
How about the gas itself? Is it good gas?
Old    TK (swab791)      Join Date: Mar 2005       05-26-2006, 6:34 PM Reply
Any FUEL injected motor has a TECH ONE port.
It is tough to diagnosis a problem like that without
the assisitance of a computer. It could be a MAP SENSOR
a THROTTLE POSITION SENSOR. and IIAC SENSOR etc etc etc.
Go get it checked
Old    Jon Allen (jon_a)      Join Date: Feb 2003       05-26-2006, 8:35 PM Reply
Sounds like a fuel filter to me. Good luck.
Old    Kvkev (kvkev)      Join Date: Oct 2003       05-27-2006, 6:27 AM Reply
Diggs it's good gas.
Jon the water/fuel seperator is the filter.
TJK it's on it's way to the shop.
Thanks GUY'S I'll post the problem when I find out.
Kevin
Old    Kvkev (kvkev)      Join Date: Oct 2003       06-16-2006, 6:31 AM Reply
The low pressure fuel pump was gumed up. The boat shop cleaned it and has run fine since
