Old    sportman            05-17-2006, 8:59 PM Reply
So I have a 2003 bayliner 185. I know not a wakeboard boat so dont trash me. I am going to put a stereo in it. Question--how do I support the radio once I do the GelCoat/Fiberglass cuts and push it through. Should I make a wood brace and glue it to the backside of the fiberglass? Also cutting a hole is scareing me a little. I hear a 5" hole saw should do the trick for the speakers. But how do I cut the rectangle for the head unit?
Thanks
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       05-17-2006, 9:12 PM Reply
Where are you going to put the HU? A pic might be useful.
Some Head Units come with some additional bracketing that will help give some support.
Old    sportman            05-17-2006, 9:24 PM Reply
Here is a pic. Doesnt come with any brackets just that small sleeveUpload
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       05-18-2006, 6:36 AM Reply
The fiberglass itself should support the weight of the radio. With the hole saw I'd recomend drilling in reverse, worked great for me....I din't even haev to tape it. Cutting out the rectangle I would tape it off.
Old    d_fresh            05-18-2006, 9:16 AM Reply
You cut the holes with a roto-zip. You should be using a marine radio install kit. That will support the radio
Old    sportman            05-18-2006, 10:50 AM Reply
any specific blade on the zip?
Old    sportman            05-18-2006, 1:05 PM Reply
Also Where can I find a Marine Radio install kit? I googled but could only find the covers
Thanks
