Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through May 19, 2006
Old     (ord27)      Join Date: Oct 2005       05-17-2006, 5:16 PM Reply
finally got the boat in the water
went with the through hull similar to the engines, instead of rivals 1.5" scoop
doesn't look great, but no other place to put it
put the ball valve in and then plumbed with pvc to the switch
Old     (ord27)      Join Date: Oct 2005       05-17-2006, 5:18 PM Reply
have 2 bags in the bowUpload
1 one the rear drivers side
Old     (ord27)      Join Date: Oct 2005       05-17-2006, 5:20 PM Reply
then on the passenger side, I went with fly highs quick connect
the hoses roll up and fit in the netting and behind the panel when not in use
Old     (ord27)      Join Date: Oct 2005       05-17-2006, 5:29 PM Reply
in the rear center
I did away with the ice chest
fiberglassed some plywood, and covered it with carpet...making a new floor
I was originally going to make a new seat
but decided to creat a hinged door that can hide hoses when not in use
or quick connect 2 fly high bricks when I want ballast
the rear area is still a project in motion
I might make a more stable "wall"
also, the switch panel will more than likely be abs plastic..in the future
..I am going to add Malibus fill/drain dash swithches in place of accessory swithes...in the future
Old     (ord27)      Join Date: Oct 2005       05-17-2006, 5:30 PM Reply
in the rear center
