Old                05-15-2006, 3:08 PM Reply
Ive been trying a FS 360 and have come close to landing it. For the 360 i let go of the handle before my other hand comes around to grab it and i cant get it down. Is there anything i can do to make this handle pass easier?
Old     (kingskrew)      Join Date: May 2004       05-15-2006, 3:17 PM Reply
If you have access, practice on a trampoline. Jump in the air, tug with both hands to initiate the spin, and then reach around for the handle-pass. If you can't get to a trampoline, you're going to have to learn it on the water. Concentrate on popping off the wake, then pulling to initiate the spin. Pull hard with both hands and you should be able to get the handle-pass. Good luck!
-Steve
Old     (garret_s)      Join Date: Apr 2006       05-15-2006, 10:34 PM Reply
both hands is KEY. Also, make sure you have your eyes aligned with the horizon. Good luck!
Old     (pittsy)      Join Date: Apr 2004       05-16-2006, 8:51 AM Reply
make sure your other hand is on the handle before you let go
