Old    Show (bigshow)      Join Date: Feb 2005       05-13-2006, 1:10 PM Reply
Here are a few of our surfing pictures from the last three weeks. Post some of yours.
New ballast has the swim platform 5 inches under the water line!
Dean adds to the lean
Dave on the Goofy Wake
Dean riding switch on the regular wake
Jack riding the Mojo Ya Baby
Kory switch on a unique knee board
Kevin said that he'd surf, maybe next time.
Me, Goofy wake is looking good, but not happy with the regular wake.
Old    Clarke (cp3)      Join Date: Dec 2005       05-13-2006, 11:27 PM Reply
That seems like a small wakesurf wake for the swim platform to be 5 inches below the water line.
Old    Tom March (tomcalabria)      Join Date: Feb 2006       05-14-2006, 3:14 AM Reply
how much weight are you holding and where do you have it located?
Old    Show (bigshow)      Join Date: Feb 2005       05-14-2006, 7:25 AM Reply
750 sacks in the rear lockers, 230 lb center tank, 270 lbs home made pop bags, 160 lb of other free weight. The swim platform goes 5 inches deep when both 750s and the center tank are filled.
Hereís my goofy-starboard setup: starboard 750 full, port sack empty to half full, center tank full, free weight along the starboard side, mostly in the bow, wake plate 100% down, and crew of three or four along the starboard side. Compared to last year a noticeably improved goofy-starboard wake.
The regular-port setup is: port 750 full, starboard sack empty, center tank full, free weight along the starboard side, mostly in the bow, wake plate 0% down and crew of three or four along the port side. Compared to last year not much improvement. When I run 12 to 12.5 mph the wake looks awesome, but I canít keep up, so we dial down to 10 mph. Looking at the attached picture this is about as good as weíve seen on the regular wake side.
Given the ballast that I have Iím not real happy with the regular-port wake that Iím getting. Not counting crew that should be over 1400 lbs or more of ballast in play. A lot of the better wakes that Iíve seen online seem to be behind larger 23 foot boats, mine is 21.5, also the hull is really an older ski hull with spray pockets and lots of contours, rather than a smooth wakeboard boat hull. The gunnels seem a little low so I donít think that I feel comfortable adding more ballast.
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       05-14-2006, 8:22 AM Reply
Ed, that isn't a bad looking wake on the port side. If you look at the picture of the guy riding backside labeled "Dean riding switch" it looks as good as any posted in here.
The only thing that looks "weird" to me is that line in the middle of the face. That seems to be where the curl starts also. Is that caused by the hull or the swimdeck?
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       05-14-2006, 8:28 AM Reply
I was just thinking. The "weak" side on my Tige is the starboard side. I simply don't have as much room for ballast, and no doubt there is some aspect of prop rotation that affects that side too. When we pull on that side, I have to turn ever so slightly to that side to clean up the face.
Old    Show (bigshow)      Join Date: Feb 2005       05-14-2006, 10:05 AM Reply
The middle wake feature is made either by the swim platform or the spray pockets, I think itís from the platform. Last season the starboard-goofy wake had a hole in the wake that we were attributing to the swim platform. The hole was a real problem for the goofy stance riders. This year with increased ballast and improved wake the goofy riders haven't been complaining.
Hereís a picture of the starboard-goofy wake curl just after the rider lost the wake. To my eye the curl starts in the upper middle of the wake, I think thatís what Jeff was noting. To me it seems like the curl should start higher.
I saw another post on the Boats and Accessories forum that someone was complaining about small Centurion swim platforms. I'm guessing theyíre smaller to help avoid surfwake problems. Actually I think in 06 they started offering larger swim platforms. Seems like bigger swim platforms would cause bigger problems. So now Iím thinking wakesurf boats should have flip-up or fold-over-in-the-middle swim platforms to keep them from damaging surfwakes.
OK enough of my wake problems, letís post some surfing pictures or should we start a new thread for surf pictures!?
The goofy curl.
Old    Scott Henderson (mudsurfer)      Join Date: Nov 2005       05-14-2006, 10:14 AM Reply
Here is a few pics from this week, The wake is almost there, I have 480 lbs of lead 300lbs of factory ballast and 300lb fat sack all in starboard rear locker, I also fill the front ballast 500lbs Its hard to see with the chase boat pics but this wake is big and longUpload
Old    Johnny Wadd            05-14-2006, 11:02 AM Reply
Here are a few. 05 MB B52 Team Edition. Stock ballast with the driver plus one 13 year old in the back.Upload
Board More/Work Less!
J$
Old    wardovision (caskimmer)      Join Date: Apr 2006       05-15-2006, 9:09 AM Reply
Shannon
Rich(dad)
Old    wardovision (caskimmer)      Join Date: Apr 2006       05-15-2006, 9:12 AM Reply
Steve
me
Old    wardovision (caskimmer)      Join Date: Apr 2006       05-15-2006, 9:14 AM Reply
this is it for now
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       05-15-2006, 9:19 AM Reply
Walzer's? You're killing me! When can we get them at retail? :-)
Old    wardovision (caskimmer)      Join Date: Apr 2006       05-15-2006, 9:29 AM Reply
YEP!! That's actually one of the production ready 3/4" boards and it rides insane. (I'm finally happy with the shape). I can't believe how much of a difference moving a few millimeters around on the board makes.
Jeff- If I don't go back down to Cabo this week Walzer and I will be coming up your way for the contest and will be bringing several boards with us.
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       05-15-2006, 9:44 AM Reply
You've GOT to make the contest - what's Cabo compared with Red Bluff? :-) Everyone KNOWS that Red Bluff in May is MUCH better than Cabo!!!!! :-)
The boards look sweet, and you caught some decent air in that one pic.
So...Cabo can WAIT!!!!!!!! :-)
Old    wardovision (caskimmer)      Join Date: Apr 2006       05-15-2006, 10:33 AM Reply
Walzer doing a little ocean testing on a 1" prototype from our last trip to Cabo.
and this is the 3/4" board Walzer based the model I was riding yesterday on (after 4 rounds of changes)
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       05-15-2006, 10:41 AM Reply
SEE! You've already done enough testing and playing in the ocean, you need some behind the boat time in Red Bluff and you need ME to get my hands on one too! :-)
Old    Itch (fullonsalesgrp)      Join Date: Jan 2004       05-15-2006, 3:58 PM Reply
Yeah Sean get those things ready I am interested.
Take tons of photos what ever you end up doing.
itch
Old    Jo Shmoe (joeshmoe)      Join Date: Jan 2003       05-16-2006, 8:34 AM Reply
sean, i've seen surfboards behind the boat, but never a wakesurfboard on the ocean, awsome! is it much harder than a shortboard to paddle?
Old    justin shock (shocker)      Join Date: Dec 2005       05-16-2006, 5:42 PM Reply
caboo <333
Old    entrust clothing (entrustclothing)      Join Date: Jul 2005       05-16-2006, 7:17 PM Reply
ive tried to paddle in on my phase 5 and i was laying down and threw the rope and was riding the wave but getting up on it was a totally different story. most wakesurf boards aren't bouyant enough to paddle in and stand up on
Old    lovinpowell (lovinpowell)      Join Date: Jul 2005       05-17-2006, 4:56 PM Reply
Those pictures look awesome, can you let us know if we can get our hands on one of those boards. I am in the market for a more aggressive handling board than the one that I have now.
Old    walt            05-17-2006, 9:19 PM Reply
Old    Lionel (lionel)      Join Date: Nov 2005       05-17-2006, 9:55 PM Reply
Walt, is that behind the Sanger? Regardless, looks nice.....
Old    walt            05-17-2006, 9:57 PM Reply
06 Bu VLX
Old    Lionel (lionel)      Join Date: Nov 2005       05-17-2006, 10:37 PM Reply
That 2nd picture is a joke!! How much weight, speed? Might be helpful for our fellow VLX owners.....
Old    walt            05-18-2006, 5:39 AM Reply
Bryan,
I'm not sure how much weight it was but it was a lot and I don't think it would take to much more.
The water was a few inches from coming over the side.
Old    wardovision (caskimmer)      Join Date: Apr 2006       05-18-2006, 8:24 AM Reply
Old    Clarke (cp3)      Join Date: Dec 2005       05-23-2006, 7:07 PM Reply
This is with like no weight. Just a couple poeple. I will post a better pic later.
Old    Travis M (travis_m)      Join Date: Aug 2005       05-24-2006, 9:02 PM Reply
does anyone have that picture of the guy surfing behind two boats wakes?
Old    4sher            05-25-2006, 9:41 AM Reply
Check out the media (action shots) section of www.inlandsurfer.com. The second and third row of pics on the first page show 2 boat surfing (with 2 Centurion Enzos).
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       05-28-2006, 8:13 AM Reply
Dennis riding frontside and backside on the Blue Lake. Upload Upload
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       05-28-2006, 8:15 AM Reply
Oh no! How did I get on the dark side!!!! :-)Upload
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       05-28-2006, 8:18 AM Reply
Yes, riding goofy does make your butt look big. :-) Upload
Old    Show (bigshow)      Join Date: Feb 2005       05-28-2006, 9:55 AM Reply
Some pictures from the 27th.
Don't for get to keep your hat dry
I like the rope toss shot
See the middle feature, that's from the hull extension
Old    lg925            05-28-2006, 10:23 PM Reply
Sean Ward - That is some wake you have behind that boat. How the heck did you get that so big? I'm jealous!!
Old    Jeff Walker (surfdad)      Join Date: Sep 2004       05-30-2006, 4:19 PM Reply
Hey Ed, nice pictures, but I can see that feature or lip is still present. Can you surf over it, or is it like a true lip where going above it is hard?
Old    Show (bigshow)      Join Date: Feb 2005       05-30-2006, 6:43 PM Reply
Jeff, the middle feature is more present on the goofy side. It doesnít bother my riding, nor does the swim platform spray. I think it makes the wake curl way too early, so the wake looks a lot worse than it is. I had a really good wake to ride on Memorial Day with just my 14 year old daughter and two of her friends, thatís only about 300 lbs of driver and watcher weight.
I have a couple of other boat/wake tweaks in mind that Iím going to give a shot this month.
Old    Derek George (wakesurfer54)      Join Date: Jun 2005       05-30-2006, 7:02 PM Reply
first run of the yearUpload
Old    wardovision (caskimmer)      Join Date: Apr 2006       05-30-2006, 7:46 PM Reply
2 pics of me and my sister celebrating Memorial Day with the family.
Shannon(citter)
(Message edited by caskimmer on May 30, 2006)
Old    wardovision (caskimmer)      Join Date: Apr 2006       05-30-2006, 9:30 PM Reply
critter in action(video)
http://www.wakepics.com/img/19150
Old    Matt Poirot (chopper515)      Join Date: Mar 2005       05-31-2006, 1:49 PM Reply
My first free ride. Memorial Day Weekend at Bull Shoals Lake in Arkansas.
Old    Trace (trace)      Join Date: Feb 2002       06-05-2006, 3:55 PM Reply
took this one of my buddy yesterday. he's about 5'-9".
big
