Old    marc (norcal72)      Join Date: Aug 2005       05-05-2006, 9:28 AM Reply
I am upgrading my ballast system on my new Enzo. I am pulling the stock tanks and replacing them with a custom sack from fly high. I want to upgrade the pump as the stock one will take a long time to fill. What is the best pump I can buy that can be hard wired into the existing plumbing? Thanks in advance.
Old    Joel Leger (jleger98)      Join Date: Oct 2003       05-05-2006, 12:33 PM Reply
Rule, Attwood, ShurFlo are a couple brands that come to mind. I guess it depends on what your current setup looks like. I've never seen a stock system in an Enzo.
Got any pics you can post?
Old    marc (norcal72)      Join Date: Aug 2005       05-05-2006, 1:04 PM Reply
i dont yet but i will get some pics and post them
Old    WAlove (masonwakerider)      Join Date: May 2003       05-06-2006, 11:04 AM Reply
The enzo uses jabsco ballast puppies to fill, you could T before the pump and run two pumps side by side to double your flow. If you wanted to switch to a high volume bilge style pump it would require reengineering the whole system.
By the way are you getting the 1500lbs side sack from fly high. Check out some of the picks on the inland surfer site. Clean surf wake 20ft back its just amasing. I was out surfing a brand new 06 last night. We had no wieght in it because we were breaking it in and with only 5 dudes the wake was massive.
http://www.inlandsurfer.com/album.asp?page=3
