Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 22, 2006
Old    Kal Cotter (kalcotter)      Join Date: Aug 2004       05-02-2006, 6:25 AM Reply
This is probably a stupid question, but I'll ask anyway. I have a 1990 Malibu, and it's the first ski boat I've owned. When it's just sitting at the dock (or moving for that matter) it takes on a lot of water. I was told that these boats take on a certain amount of water, and it's pretty much normal... but that makes no sense to me.... I'm wondering if I was misinformed.
thanks,
kal
Old    Tickle (showtime)      Join Date: Nov 2005       05-02-2006, 6:42 AM Reply
you are correct --they do take on a CERTAIN amount of water --but should not take on a great amount of water. check your packing seal and nut at your prop shaft. good chance it just needs to be tightened...
Old    Kal Cotter (kalcotter)      Join Date: Aug 2004       05-02-2006, 7:18 AM Reply
the nut at the prop shaft? you mean where it connects to the engine, or where it goes thru the hull?
Old    eric fox (fox)      Join Date: Jul 2002       05-02-2006, 8:10 AM Reply
Where it goes through the hull. Should only drip once every 10 seconds or less. I am not certain exactly what the figures are, but if it's anything more than a drip, you have an issue.
Old    walt            05-02-2006, 3:43 PM Reply
Hal,
There's a packing gland that houses a small waxed rope (packing) It's supposed to drip to keep the packing lubricated. If you over tighten it you run the risk of burning up your prop shaft.
It's possible that it just needs to be tightened or replaced. It's no big deal either way.
If you don't already have a auto bilge pump have one installed or do it yourself. It will kick on when ever the water gets to a certain level in your bilge.
You can also install a drip-less packing system.
