04-25-2006, 9:10 PM
I have been busy working on finishing my new charging system. Balmar 94-210 alternator Balmar Digital Duo Charge Balmar Max Charge regulator 4 Sea volt 92 amp hr battery's 1 Blue top optima 1 Blue Sea battery switcher 30 feet of Red 0 agw 30 feet of Black 0 agw Im still waiting on the custom pully's. I am having the water pump and crank pully's turned.
04-25-2006, 9:18 PM
Im doing things a bit diffrent on this charging system. The main charge feed off the back of the alternator will charge the large bank first. Then the extra charge will spill over and threw the digital duo chagrer that will top off the blue top Optima. Im using the battery switch to remove one battery bank from the other. The switch will connect diectey to the Optima as to use it in the event the main batterys are so dead the boat wont start. The Optima will never see use/draw unless the boat wont start. The large battery bank will do everything It will run the boat and power the stereo ect. No more solonoid.
04-25-2006, 9:29 PM
So the Optima Blue Top is just a backup battery?
04-25-2006, 9:38 PM
Yupp. The blue top just dose nothing unless Im dead. The Balmar DDC takes the charge from the main battery bank and breaks it down to a charge rate that the blue top Optima likes. When the Optima reaches full charge it go's to a float charge to keep it toped off. The DDC will not let voltage drain backwards from the Optima and into the large battery bank. And there will be no chance of the large battery bank draining the Optima because the battery switch keeps both banks away from each other unless I have the switch set to both.
04-25-2006, 10:08 PM
Very nice. I think things should be done with one of two objectives. Either make it look really trick or make it look like it came from the factory that way. This project demonstrates your ability to do things as if they were done at the factory. Looking at the switch baseplate. Looks good but you probably could have done it with 3/4 plex and saved yourself some labor. After making my second dash plate out of plex I realized that it saved me a ton time. It routered out as easily as particle board but the finish ended up much smoother so I didn't need to sand it as much, no filling, and it's completely waterproof unfinished. The painting prep was also easier. No waiting for bondo to dry. You can also drill and tap it for mounting purposes.
04-26-2006, 7:43 AM
Ill explain my Photo's #1 Alternator gound 0 agw #2 The O Agw power and ground running to the alternator #3 The old charge wire 2 agw and the new charge 0 agw wire #4 Hogging out the mounting foot #5 Battery switch #6 New Smart regulator #7 Battery bank A #8 Front of motor w/o pullys #9 Drivers side battery and switch #10 Emergency starting battery I went with the welding wire to connect the battery's. Its not as Bling but its suposed to transfer current better, It has allmost no shielding on it. The Sitnger wire used at the shop has a thick skin to help stop noise comming threw the wire. Because my wire/batterys are not running near any of my amp's I didnt think the thinner shiled on the welding cable would transfer any noise threw my system. We will see. If I have a buzz or humm Im gonna be pissed LOL. Looking forward to getting this thing going. I will next have to program the onboard regulator and the Digital duo charge
05-08-2006, 8:28 AM
05-08-2006, 9:04 AM
oooohhhhh weeeeee. Good lookin! Did you feel your batteries to see if they felt hot from the charge?
05-08-2006, 9:21 AM
Luke: No I didnt check. The charging system has a temp senc that's attached to the center of the main battery bank that retards the charge if the batterys get warm. Fully automatic
05-08-2006, 9:27 AM
That is a sick sick setup. 170 Amps at 1200 RPM?? Wow. I really dig the custom belt pullies, although I thought you would have anodized them.
05-08-2006, 10:17 AM
Grant how many alternators have you been through to this point that would cause you to go to this extreme level of charging? I did have to fabricate some brackets for mine when I went to the high amp (95)alt because they didnt make a high amp kit for the standard frame that fits in the merc 5.0 I/O. Fortunately for me im running the serpentine and not the 1/2" belts, pulley swap was all that was needed. Those pulleys look sweet even though they are not anodized. Also what is the reason you didnt go with the golf cart batteries, the maintenance and lack of requirement for the AGM's? I know the golf carts would have been cheaper and have more storage but there size is odd.
05-08-2006, 11:13 AM
whow...170 amps. That's the only intelligent thing I have to say today. :-)
05-08-2006, 12:10 PM
So whats the final bill of this charging system upgrade? Way overkill but very sweet non the less.
05-08-2006, 12:26 PM
Bob: I guess I have been threw like 3 diffrent alternator set up's before I got to this point. For my set up golf carts are no good. Space and not being able to lay them on the side and having to keep checking is lame. But for other set ups they work great. Nate:Im guessing I spent almost $2500. It might seem like overkill to someone not familiar with how a system like this go's threw power. Like alot of stuff I have been doing It dosent seem normal at first but over time I bet you will see more and more people up grading their marine battery and charging system's.
05-08-2006, 3:01 PM
~Watch me send Grant into a customizers coma~ So Grant what's with the sticker on the Port Bling-o-meter, couldn't you have made that out of carbon fiber or something?
05-08-2006, 3:49 PM
Grant, If you didn't own Sound Illusions, would you still have built your killer charging system to this extent? I guess I'm wondering if you help justify it as Product/Service Research & Development and advertising? (Message edited by yosquire on May 08, 2006)
05-08-2006, 4:19 PM
Craig: I dont own Sound Illusions, Clay does. I build thing's because I need or want them. I share project's with people to show them what Im doing and get Idea's and direction. Lots of times I have posted projects in the work's and got some great ideas how to make it beter. As far as advertising, Yea I can just see people lining up to drop $3,000 on a "OverKill" charging system.
05-08-2006, 5:36 PM
Cost of Alternator $1200 Cost of Pulleys $700 Cost of controls $600 Being able to wakeboard and party with your friends all day while rockin' the tunes without having to worry about your batteries going dead, PRICELESS!
05-08-2006, 7:55 PM
Grant your charging system looks awsome !!!!!!
05-08-2006, 8:03 PM
Nice job Grant !
05-08-2006, 8:29 PM
I am with Mikeski.....absoloutely PRICELESS. I personally would seriously consider going this route to get rid of the headaches associated with drained batteries. Thanks to Grant for doing all the leg work associated with a charging system of this caliber.
05-08-2006, 8:45 PM
Super sweet as usual Grant. I'm starting to believe your "bar" has no height limit. lol
05-08-2006, 9:25 PM
Grant , I AM DISAPPOINTED!!! Cost of Alt -$1200 cost of Pulley $700 Cost of controls - $600 Charging System without L.E.D's Worthless!!!!! J/K It looks awesome as always!!! Have you guys heard on anything with Carbon Fiber Yet? Any other options for covering dash item and grab handles???
05-09-2006, 2:40 AM
Nice, I especially like that mounting plate for the Perko switch. One question about the two batteries mounted in the bow tilted to the side like that. Knowing that they'll take a fair amount of pounding up there, are you worried at all about one of them cracking along the seem where the top and bottom of the battery is sealed and leaking fluid out onto the carpet?
05-09-2006, 6:31 AM
Grant - What was the voltage at idle, or around 750 rpm's? With my upgraded alternator I get 14.4 at 900-1000, but would love to have the voltage back at idle. (Been thinking about dual alts.)
05-09-2006, 6:58 AM
Here is a more accurate cost break down. Balmar 94-210 alternator $1200 Balmar Digital Duo Charge $200 Balmar Max Charge regulator $250 Balmar Alt Tem Senc $40 Balmar Bat Temp Sence $40 4 Sea volt 92 amp hr battery's $720 1 Blue top optima 1 Blue Sea battery switcher $40 30 feet of Red 0 agw $60 30 feet of Black 0 agw $60 Nick nack's $50 Pully's $715 Total $3,321 Mike Exactley, Im glad some people know the value of not running out of juice, LOL guy's thanks for your complement's, Joe M What's your voltage @ Idle. My alternator dosent seem to do much @ Idle. It seems charging starts at around 1200 Rpm's My Idle is around 800. Balmar said that because Ski boats have sutch a large Rpm range making the pully smaller and bumping up your low Rpm charging range would make the alternator spin way to fast at higher rpm's So Ill keep the pullly I have. Rob: The batterys are sandwiched between the floor and the seet bace they arent going anywhere. If they were ketching air then yes I would be worried Ken: when my batterys are fully charged im seeing 14 volt's with 40-50 amp's Thats what the 10th pic was when I first fired up my boat. When my batterys are discharged Im seeing 13 and 170 amp's (11th and 12th pic above)
05-16-2006, 9:20 AM
I was able to put a few more day's/hr's on my system and Im pleased to report its awesome. I cant tell you how happy I am to have the system charging while the boat is idleing along and the system is pumping. Normaly with the old system I would be under way (Idle Speed) 800 rpm's and if the system was pumping the voltage would dip to 12 volts and some times lower and thats with 5 fully charged up battery's. Now Im seeing 13.2 13.8 volts at 800 rpm's and thats while the system is pumping. On plain Im seeing over 14.volts with a heavy load. Yes they system was expencieve and it wasent easy to do, but It did or does exactley what I wanted it to do. As far as beinging Overkill "sometimes you need a cannon to kill a fly" LOL (Message edited by grant_west on May 16, 2006)
| Thread Tools |
| Display Modes |
Linear Mode
