Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 21, 2006
Old    Druffel (dedicatedwse)      Join Date: Apr 2006       04-13-2006, 2:03 PM Reply
I have a lot of questions about boat electrical systems and was wondering if any of you could guide me to a good online source of info. I was at Boater's World the other day asking questions and the guy “helping” me was full of sh**. I can't stand people who won't just admit that they don't know what the hell they are talking about.
I know that this topic is discussed on this board, but I’m hoping to find a more comprehensive online guide instead of searching through 100’s of archived message board threads.
Sample of questions I have:
How do I calculate when to upgrade alternator?
When to use blue tops, when to use red tops?
Can I use red with blue?
Is there any reason to use red with blue? (one battery for stereo system, one for cranking)
Can/should I use my old battery with new battery (not in parallel)
What does it mean to be marine rated batteries/alternators? Does it really matter?
Thanks
Old    Rod McInnis (rodmcinnis)      Join Date: Sep 2002       04-14-2006, 11:13 AM Reply
If your battery is going dead while you are running, or they don't get fully recharged during the length of your ski runs then you need more output from the alternator. A good sanity check is to carefully watch the battery voltage. If you can read your dash volt meter well enough that's fine, otherwise put a digital multi-meter right on the battery.
If you are at wakeboard speeds or higher and the battery voltage is above 13 volts then you are doing okay. If the voltage is 12.5 to 13 volts, and your batteries were seriously discharged AND you are running a lot of stuff (stereo, ballast pumps, etc) then you are okay but marginal.
If the voltage is less than 12 to 12.5 volts you aren't charging the batteries and unless you reduce the load (turn off the heater, lights, ballast, etc) you will eventually end up in trouble.
If the voltage is less than 12 volts you won't be running that way for very long.
The red tops can deliver higher peak currents for starting purposes (see the chart here: http://www.optimabatteries.com/publish/optima/americas0/en/config/product_info/automotive/starter.html)
I would recommend using the blue (deep cycle) because your boat probably isn't going to need the extra surge capability of the red top. You need that extra current when encountering a "hard start" situation, like when you are at 9000 feet elevation and your car has been sitting all night in 20 below temperature. Since I don't think you will be using your boat in such conditions it is safe to assume your starting conditions won't ever be too bad.
What you are likely to do is run the battery down (deep cycle) running the stereo.
If you are going to keep the two batteries separate, always using the red for starting and the blue for the stereo, yes. If you are ever going to put the battery switch in the "BOTH" position and leave it there then I wouldn't recommend having two different battery types.
>Is there any reason to use red with blue? (one >battery for stereo system, one for cranking)
As I said above, having one of each is fine IF you keep them separate. If you were likely to encounter a "hard start" situation then that would be the way to go.
I recommend running only the deep cycle batteries (blue top). They will provide adequate current to start your engine and they will tolerate the deep cycles you are likely to throw at them a lot better.
Ditto what I said above. It is okay to do IF you keep the batteries separate. If you ever combine them then you have an "unknown" situation. It is even more important to not combine two different types of batteries, such as a flooded lead acid and the AGM (Optima).
For a battery it means it has screw post on top with a wing nut, and often also means it is a deep cycle battery. There is no reason to run use a "marine" battery.
For the alternator and many other components of the engine electrical and fuel systems the "marine" rating is MUCH more important.
On a car, any spilled/leaked fuel drips out on the ground. Fuel vapors, which are heavier than air, also flow down to the ground and can drift away. On a boat, the hull traps the vapors and can easily create an explosive mixture.
The marine rated electrical/fuel components are designed to provide an extra level of safety. Fuel systems are built to be more resistant to leaking and if they do leak to spill it either overboard or into the engine air intake. Electrical systems, especially the starter and alternator, are designed with a flame arrester.
Many people erroneously believe that the marine alternators and starters are "sealed". This not true, as doing so would block the cooling they require. What they do have is a flame arrester screen over the air vents. While the screen may look like it is useless it is actually a very viable device. Fuel vapors WILL get into where the brushes will arc, and they will get ignited. The difference is that the volume inside the alternator case is sufficiently small that the "explosion" is very small. When the flame wave front hits the screen its thermal mass cools it down and it will not ignite the vapors just outside the screen. It works.
Installing a non marine alternator or starter in your boat removes half your safety factor. If your fuel system springs a leak, or you carry a gas can that leaks, or the gentle breeze blows the fuel vapors into the boat on a fill up then you have all the ingredients necessary for a disaster.
Old    Bruce Mac (brucemac)      Join Date: Dec 2005       04-14-2006, 1:43 PM Reply
Rod
as always your wisdom and insight amazes me.
/end suck up
i have a question though. you refer to the blue tops as AGM. this is something i've been confused about ever since deciding on an onboard maintenance charger. on their website they say nothing about AGM, and in their product spec sheet for both the d31m and d34m they state at the top of the page "Description: High power, dual purpose engine start and deep cycle, sealed lead acid battery".
http://www.optimabatteries.com/publish/optima/americas0/en/config/product_info/marine/product_spec_sheets.RowPar.0001.ContentPar.0001.Co lumnPar.0005.File.tmp/D34M_082104.pdf
i always thought AGM and lead acid were two different types. what gives? is AGM a type of lead acid battery then?
(Message edited by brucemac on April 14, 2006)
Old    Mikeski (mikeski)      Join Date: Aug 2003       04-14-2006, 3:15 PM Reply
AGM (Absorbed Glass Mat) batteries: A dense fiber matting between the plates and a liquid electrolyte provide
similar features to gel batteries but are much more rugged since they were designed for use in aircraft and rough terrain vehicles. AGMs (like gels) are very sensitive to overcharge. 14.38 volts is recommended for the initial (bulk) charge and 13.38 as a "float" charge.
stolen from: http://www.phrannie.org/battery.html
see the poop sheets www.phrannie.org
Old    Bruce Mac (brucemac)      Join Date: Dec 2005       04-14-2006, 6:24 PM Reply
huh, okay so that makes sense, but how come optima calls them "lead acid" and rod refers to them as AGM
is AGM a sub-category of lead acid or a "better" type of lead acid? forgive me for asking, i guess it doesn't really matter, i just want to know.
Old    Druffel (dedicatedwse)      Join Date: Apr 2006       04-15-2006, 3:08 AM Reply
Rod,
Thank you. I appreciate the time you put into your post! That was much more information than I was expecting!!
Old    Druffel (dedicatedwse)      Join Date: Apr 2006       04-15-2006, 8:49 PM Reply
Any suggestions on who offers the best prices for the blue tops?
Old    JTW (sangerlover)      Join Date: Sep 2005       04-15-2006, 9:00 PM Reply
Some Costco stores sale them for $150.00 ea.
Old    Mikeski (mikeski)      Join Date: Aug 2003       04-15-2006, 9:06 PM Reply
There have been quite a few threads recently regarding charging systems and batteries. We seem to take a pretty hap hazard approach at solving these problems, I know I am guilty.
I figure out energy use in buildings for a living so I should be able to figure it out for a boat. So yesterday I started making some assumptions and ended up putting together a little spreadsheet that should help us figure out what to expect from our systems. I started with my system knowing how it operates. The spreadsheet is attached, try it out and see what you think. Please e-mail it back to me with feedback for improvement. Maybe if we can get this spreadsheet working well somebody could host it for everybody to use.
Mike
mikeskiw@gmail.com
application/octet-streamUpload
Alternator calcs.xls (17.4 k)
Old    Druffel (dedicatedwse)      Join Date: Apr 2006       04-15-2006, 9:18 PM Reply
Mike -
I wasn't able to open your spreadsheet. Feel free to send the excel file to my email address and I'll take a look and provide comments.
ch74druffel@hotmail.com
Blue-top price -- Best I've found so far is $196 w/ free shipping etc... from www.1st-optima-batteries.com
Costco online doesn't sell them. I'll have to check my local store.
Old    Druffel (dedicatedwse)      Join Date: Apr 2006       04-15-2006, 9:36 PM Reply
Now we're cookin'
http://bigtimebattery.com/store/optima_d31M_marine_deep_cycle_battery.html
$159 no tax, no shipping!
