Old     (kitstocks)      Join Date: Aug 2005       05-16-2006, 8:57 AM Reply
When trying the 180 and 360 should you have fins on your board? If you do what size and how many?
Old     (entrustclothing)      Join Date: Jul 2005       05-16-2006, 9:04 AM Reply
i can spin 360s with fins on my board, i ride a phase 5 prop with a 1.5" fin on the back
Old     (bigshow)      Join Date: Feb 2005       05-16-2006, 9:27 AM Reply
Looks like Kit has a Broadcast. The fins on the boardcast are maybe 3 to 4 inches. Kit the next time I ride I plan to remove the center fin on my Broadcast to see if the board loosens up any.
I also have a Trick Boardz Mojo. The Mojo is a symmetrical board. I'm going to take off one of the fins so when I start I can chose to start with a fin in the back or not. The Mojo is already pretty lose compared to a Broadcast, it will be interesting to see how it rides with out a fin.
Old     (surfdad)      Join Date: Sep 2004       05-16-2006, 9:42 AM Reply
Entrust!!!! You retired that LF board?! :-)
You can spin a surface three with any depth fins. Check this article:
http://www.wakesurf.net/Home/tabid/36/mid/572/ArticleID/10/Default.aspx?ctl=CMS_Articles_View
The key with deeper fins is to break them loose, otherwise you just track a big circle and typically spin out the back.
This is James in the middle of his surface 3, he rides with 3.5" fins.
Old     (caskimmer)      Join Date: Apr 2006       05-16-2006, 9:42 AM Reply
I use to ride exclusively without fins and it does makes tricks like shuvits and switch stuff easier but IMO surface 360s are easier with fins.
(Message edited by caskimmer on May 16, 2006)
Old     (surfdad)      Join Date: Sep 2004       05-16-2006, 9:47 AM Reply
How tight a circle will those Walzer's turn? I know for me, recovering at the bottom of a 3 is easier with fins...I tend to over-rotate wind up doing a 400 :-)
Old     (entrustclothing)      Join Date: Jul 2005       05-16-2006, 9:55 AM Reply
yeah jeff i retired the LF skim skate, i love the phase 5! its super fast and cuts really nice!
