03-27-2006, 10:15 AM
03-27-2006, 2:05 PM
make sure the plugs are pushed into the splitter all the way. Ive had problems with that before.
03-27-2006, 3:36 PM
Thanks for the tip. I am pretty sure they were all the way plugged in. We thought of that right away and much to our disappointment that wasn't the problem. Any one else have any other suggestions?
03-28-2006, 8:54 PM
With Pioneer's IP-Bus network, two remotes will NOT work together. This is different from Clarion and Sony. Sorry.
03-28-2006, 10:03 PM
how much do you want for your extra remote that won't work ?
03-29-2006, 9:15 AM
Jason I am thinking you may be right. But Clint, I am going to keep trying to figure out a way to make this happen. If I can't I'll let you know what I want for it. Pioneer says its possible, so we'll get back on the phone with them.
03-29-2006, 6:41 PM
The "70"s dont use the bus network only the 1/8th mini plug. My guess is one of the remotes is bad. They will work 2 together, I've done it before.
03-29-2006, 6:55 PM
Could it be that we have a bad splitter? I just got one from radio shack. I don't know if they are any certain brand or anything or even if that would make a difference.
03-29-2006, 7:08 PM
Oops, thanks for correcting me Chris. Does it rely on a stereo 1/8" to work correctly? Maybe the splitter Andrew has is mono?
03-30-2006, 6:47 AM
Did you check what Chris said about the plugs being pushed into the splitter all the way. When i installed my Sony remote i had issues with it not working correctly...i did not have the 1/8" plug pushed in all the way. And Jason has a good point. Do they work independently? In other words if you only hook one up at a time does each one work?
03-30-2006, 12:05 PM
It does have to be a stereo splitter. And yes it may be a bad splitter
03-30-2006, 2:35 PM
We checked and it is a stereo splitter, $5.99 from radio shack. Each remote has a constant power wire, a ground and a plug. Both remotes are split into the same constant power on the head unit. Could that be making a difference? I don't see how it could, but I am running out of options. I know the front remote works fine. We are going to double check the rear remote Saturday, but i am pretty sure we tested it already. I am not 100% sure what the ground wire on the rear remote is run to, but again I don't see how that makes much of a difference. So unless the constant power wires are run wrong, I seem to have exhausted the possibilties. Anything else before we get back on with Pioneer? By the way, thanks a lot for all your help on this issue.
03-31-2006, 9:25 AM
hey, this is just a guess, but are you sure that it doesn't need to be a mono splitter? maybe it wouldn't make any difference, but at $5, maybe it would be worth bring one with you to try.
03-31-2006, 9:36 AM
Just to let you know incase you didn't already know, the power and ground wires are only for the illumination. Not trying to step on your toes.
03-31-2006, 10:22 AM
Do like you said and try each one independantly then if both work try a new splitter.
03-31-2006, 6:24 PM
I have pioneer head unit about 1 1/2 years old with same remotes (not digital remotes) had 1 remote go bad, but beyond that works great. I'm an idiot when it comes to installs, but you can definantly get 2 remotes of a pioneer unit.
04-02-2006, 6:20 AM
OK I went out yesterday and tried each remote individually. They work fine. I made sure every plug was in all the way. I plugged them both in and most of the buttons worked right, but not all. The I had the idea to twist one of the plugs and when I twisted it just the right way, it worked. This wasn't on the splitter where I twisted it, but on the plug into the unit. By the time I got to the lake it had untwisted, so I need to twist to the right point and then tape it so it stays. Thanks for the help everyone.
04-17-2006, 9:35 AM
As an update to anyone the reads this post for info on the same problem - it ended up being a bad remote on the back. We kept having problems and just bought another remote to try different combinations and found that when we replaced the back one everything worked fine. Now I wonder if we could have (or still can) use 1 displayed remote at the helm with the non-displayed in the back......
04-17-2006, 12:47 PM
NO!!! unfortunately they dont work together. Have been through this and found out the hard way. Spoke to the pioneer rep yesterday and he told me its a problem that they are aware of but dosen'tsee any fix for it in the near future.
| Thread Tools |
| Display Modes |
Linear Mode
