Old     (depoint50ae)      Join Date: Jul 2005       03-07-2006, 6:42 PM Reply
NVS Addiction speakers are coaxial. Is that the same as Dual Voice Coil?
How many speaker wire connections are there on these speakers?
If I wanted to run a pair of these speakers at 2ohms I would use a 1 channel or bridged 2 channel 4ohm amp and wire the speakers in parallel like in the following illustration?
Thanks for the help
(Message edited by depoint50ae on March 07, 2006)
Old     (depoint50ae)      Join Date: Jul 2005       03-07-2006, 6:56 PM Reply
If I used a zapco 500.1 amp for the above example and ran it at 2 ohms will the 500W be split into 250W per speaker or will it be 500W at each speaker?
Old     (derby)      Join Date: Nov 2005       03-07-2006, 7:56 PM Reply
Depoint,
Impedance is calculated like resistance. For instance two loads in parallel would be, 1/R1 + 1/R2 = 1/Rt. In series it would be R1 + R2 = Rt.
That means the total impedance of your diagram is 1 ohm. To match a 4 ohm amp with two speakers in parallel the impedance of the speakers would have to be 8 ohms each.
To really answer you question try the search feature. I foulnd this that has info from the man himself.
http://www.wakeworld.com/MB/Discus/messages/3183/281911.html?1139167778
Peace,
Derby
(Message edited by derby on March 07, 2006)
Old     (depoint50ae)      Join Date: Jul 2005       03-07-2006, 8:28 PM Reply
Derby I have read and had a few posts on that one but thanks.
The NVS addiction speakers are 4 ohm speakers so the diagram is off. With two 4 ohm speakers the total impedance would be 2 ohms right?
Old     (derby)      Join Date: Nov 2005       03-07-2006, 8:31 PM Reply
correct
Old     (akdoc)      Join Date: Feb 2004       03-07-2006, 8:33 PM Reply
Correct, each speaker is 4 ohms, so if you wire it in parallel your amp will see a 2 ohm load. If you use the Zapco 500.1 each speaker will see 250 watts RMS.
Old     (biker_jimm)      Join Date: Feb 2006       03-08-2006, 1:25 AM Reply
Hey not to get off the question topic.
Quick question. Every time you wire up in parallel 4+4=2+4=1 does your distortion level double or not every time you lower resistance whether you pump up total wattage or not.
Old     (depoint50ae)      Join Date: Jul 2005       03-08-2006, 5:35 AM Reply
I am assuming that these speakers will have separate connections for the 10" woofer and the 1" tweeters. Should I hook the coaxial speakers in each can in series and the separate cans in parallel or is there a built in crossover?
This stuff is finally starting to make sense.
(Message edited by depoint50ae on March 08, 2006)
Old     (ian30)      Join Date: Jan 2005       03-08-2006, 6:36 AM Reply
There is only one connection - built in crossover
Old     (depoint50ae)      Join Date: Jul 2005       03-08-2006, 7:41 AM Reply
Awesome. Thanks.
