Old    d_fresh            03-08-2006, 9:26 AM Reply
I purchased a '98 PS205 last fall. I plan on loading it up with 440lbs across the bach, 440lbs on each side of the engine, and 440lbs in the bow. Is the 310hp with standard trans sufficient. Also have a Acme #543 prop to install.
Old    Byrd (byrd)      Join Date: Dec 2005       03-08-2006, 9:30 AM Reply
It should be ok. I assume that is a 4-blade prop for that boat. If so, you should be fine.
Old    Airmousam1 (mitchm)      Join Date: Sep 2002       03-08-2006, 9:40 AM Reply
s/b fine. I run 1100lbs in my 2000 205 and it's fine
Old    Stanfield (stanfield)      Join Date: Mar 2004       03-08-2006, 10:05 AM Reply
Ran w/ 2k most of the time in my 93. No issues.
(Message edited by Stanfield on March 08, 2006)
Old    Tickle (showtime)      Join Date: Nov 2005       03-08-2006, 3:37 PM Reply
i had 1900#'s on friday in my 94 205 plus 3 peeps and had no trouble... stock 3 blade prop too.. most weight i have ever had and the wae was literally awesome...
Old    R M (dr_inc)      Join Date: Mar 2005       03-09-2006, 1:27 AM Reply
2500lbs and 6 peopel in the boat and it was heavy and slow but it worked...(05 x2 Same hull as a 205)
Old    Small Light (stephan)      Join Date: Nov 2002       03-09-2006, 9:07 AM Reply
My dad has a '98 205 except we have the Corvette LT1, I love that motor. Always fires first turn and has mad power. We run a 600(550 filled to the point of bursting) in the back, 350's on the sides, another 550 in the walkthrough and last time we rode we had 8 people. the wake was tight! We have the stock 4 blade and that is what will help the mst, get a correct pitch 4 blade.Upload
