Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 15, 2006
Old     (gandr_nautique)      Join Date: Feb 2006       02-20-2006, 12:30 AM Reply
Was thinking about putting 220lbs of lead up front in my Nautique 94 has anyone any suggestions or tips on glassing it in or ways of keeping it in place so it doesn't shift around.
Old     (badknees)      Join Date: Aug 2005       02-20-2006, 1:23 AM Reply
Lead is HEAVY. Wrap it in towel's or wrap it in duct tape, distribute it evenly and it most likely won't move around at all.
Old     (gandr_nautique)      Join Date: Feb 2006       02-20-2006, 2:13 AM Reply
What would you think would be the max you should put up front? As it is hard to move around!
Old     (superairdawg)      Join Date: May 2003       02-20-2006, 3:52 AM Reply
a bud of mine runs about 600 lbs in the nose of his SAN, which makes it miserable to drive and doesn't do much for the wake (my opinion). I think about half that is probably optimal, but depends on how much you have elsewhere in the boat.
Also, if you're using lead I'd keep it in smaller chunks, like 50lb chunks max. That'll both make it easier to move around plus it'll be more likely to fit.
Old     (bughunter)      Join Date: Nov 2001       02-20-2006, 4:59 AM Reply
We use PVC pipe. 3' x 2" with endcaps. Cut the lead in smaal chunks, fill the pipe and put endcaps on it. Easy to handle and very clean.
Old    ematthew            02-20-2006, 5:58 AM Reply
If you use PVC pipe, how do you keep the pipe from rolling around inside the boat?
Old     (ruffneckrider)      Join Date: Jan 2005       02-20-2006, 10:02 AM Reply
Hey robbie I see your from Ireland. I'm sure you must know Peter from wakboardIreland he can tell you!and if you happen to talk to him tell him to get in thouch w/ me that guy kills it! Good luck happy ridding.
