Old                10-21-2005, 7:56 PM Reply
toolfan or whoever, how can i slow or speed up a clip in avid?
man... i feel like a rookie all over again.
Old                10-21-2005, 8:11 PM Reply
nevermind i figured out... had to directly drag it onto the subclip without holding alt
Old                10-23-2005, 10:46 AM Reply
you know what... i didnt figure it out... tsk tsk on me.
okay toolfan, enlighten me if you would please on how to slow down or speed up a clip? like what effect do i use, and what procedure within the effect to change the speed?
thanks,
Cody
Old    toolfan (toolfan)      Join Date: Jul 2003       10-23-2005, 4:23 PM Reply
load the clip, then look for the icon that looks like a italisized clip. it is basically a sideways looking clip with lines behind it like it is moving. then you basically type in the percent to speed it up or slow it down. put a negative sign in front of it, if you want it to move backwards.
when i get to work tommorrow, i will be more precise. i am on the road 90% of the time with my new job.
email me if you want better instructions over the phone. i hate typing.
Old    Brennan (z1034ever)      Join Date: Oct 2002       11-02-2005, 5:35 PM Reply
f9 motion effect
(Message edited by z1034ever on November 02, 2005)
Old                11-10-2005, 4:45 AM Reply
how do you export video from avid so it actually works correctly? i've been trying to export for the web but i cant get it compressed enough through avid to be under 20mb. then when it does export, compressed or uncompressed, it looks like it runs at 6fps even after changing the frame rate in the export settings... can someone give me a step by step for exporting for the web through avid?
Old    toolfan (toolfan)      Join Date: Jul 2003       11-18-2005, 7:28 PM Reply
i wish i could be better help, but I only export at ultra high quality(1:1, same as source).
i would recommend exporting it at a high quality, then use QT to compress it. its basically the same thing that Avid does but it can be better.
