Old    Robert Marchenese (princeslik)      Join Date: Jun 2002       06-25-2002, 12:06 PM Reply
Can anyone give me tips on how to do a Krypt and S-Bend. I can do my 180's, 3's, Backroll, TS Backroll, Switch Backroll, Tantrum, Scarecrow, and Raley. I need to move on...anyone got any tips or tricks I should be learning now after these? Deff need to work on my roll to revert.
Old    dannyboy            06-25-2002, 6:33 PM Reply
next you should do ts and hs rolls to revert, then after that try either a mobius or whirly. if your good at raleys try a krypt, then move to blind judge.
Old    gordon523            07-04-2002, 7:04 PM Reply
if i were you i would work on switch backroll to revert first but if it is not going for you just go for the krypt, if you raleys are solid. all you have to do is when you pull in for your landing let go with your lead hand on your way down it the baord will float back under ya.
Old    matthew            07-06-2002, 2:02 PM Reply
S-Bends can be a hard trick to learn. I took more of a beating than I did trying to learn my raley's. My secret is when you come off the wake and stand tall, dip your lead shoulder and REALLY tuck your chin on your opposite shoulder ALL THE WAY THROUGH THE TRICK untill you see the water. Then pull it down like a normal raley. It all happens pretty fast so be prepared mentally for what your going to do as well. Hit the wake knowing your going to do it. It REALLY REALLY hurts when you half ass it and land on your back or the small of your neck upside down. I got the breath knocked out of me several times. Be really comfortable with taking your raleys HUGE, this will help tremedously. Good Luck.
Old    Mike (blaize)      Join Date: May 2000       07-30-2002, 1:00 AM Reply
Work on grabbing all your tricks if you aren't already. Then throw a HS Front Flip.
Old    matthew            07-30-2002, 11:26 AM Reply
I do grab all my inverts...or at least the ones that are possible. Never heard of a grabbed whirly. :-)
