Old    Ronia (ladythump)      Join Date: Jul 2004       10-07-2005, 1:25 PM Reply
Do you need to keep the camera pointed at the center of the wake and start shooting when the rider enters the frame?
or do you follow the rider with the camera and let the editting software make the sequence?
Old    Bill Nestleroad (the_regulator)      Join Date: May 2004       10-10-2005, 9:09 PM Reply
either should work. not sure how well the rider will be in focus if you shoot the center of the wake though.
Old    Walt (Walt)      Join Date: Jan 2003       10-10-2005, 9:28 PM Reply
If you sit in the back center of the boat and focus on the rider while he's in the middle of the wake your focus will not change no matter where the rider goes. (Pendulum)
I've never shot sequence but I'm guessing that it would work out better if you didn't pan with the shot.
Focus manually or use focus lock and keep the camera pointed at the center of the wake and fire away.
I think it would be easier to stitch the shots together in PhotoShop this way.
I'm just guessing though.
Old    Walt (Walt)      Join Date: Jan 2003       10-10-2005, 9:31 PM Reply
There was someone in the wakeboarding forum doing sequence shots a few weeks ago and they looked great. try doing a search.
Old    Walt (Walt)      Join Date: Jan 2003       10-10-2005, 9:34 PM Reply
http://www.wakeworld.com/MB/Discus/messages/65919/200240.html
http://www.wakeworld.com/MB/Discus/messages/1/250334.html
Old    Rich Dykmans (richd)      Join Date: Oct 2003       10-11-2005, 6:13 AM Reply
I've found that you can pan a little bit but the background has to be right to get away with it.
Old    Tiffanator (ladyboarder)      Join Date: Feb 2001       10-11-2005, 10:52 AM Reply
I pan a little on mine, the background is going to change some because you are not perfectly stationary. I've never had problems stitching together the sequences though. What I do is pull in all of the images to photoshop and leave them full size. I change the opacity so I can see both images and line up the trees or wake as best I can. Then I create a layer mast and erase what doesn't match.
Couple sequences I've done, my friend took the pics, I stitched them.
http://i10.photobucket.com/albums/a144/Tiffanator/Tiffany%20Wakeboarding/Crowsm.jpg
http://i10.photobucket.com/albums/a144/Tiffanator/Tiffany%20Wakeboarding/Tiffswbrsm.jpg
http://i10.photobucket.com/albums/a144/Tiffanator/All%20Crashes/swbrbadsm.jpg
This last one I shot and stitched... Don't know what happened in the upper right corner... looks like I hit that layer instead of the layer mask with the white paint.
http://i10.photobucket.com/albums/a144/Tiffanator/All%20Crashes/stevecrashsequence.jpg
