Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 14, 2005
Old    srxboy            10-07-2005, 1:10 PM Reply
I have a 98 supra comp and I am going to make my own tower, I was looking for any advise or tips. I am planning on using 2" tubing, but I was woundering where I can get the hardware to mount it to the boat. I am thinking on a swoop style, but will see what I think when I start building.
Old    Nacho (denverd1)      Join Date: May 2004       10-07-2005, 1:23 PM Reply
rio from Boss Accessories should be able hook you up
Old    Nacho (denverd1)      Join Date: May 2004       10-07-2005, 1:24 PM Reply
I guess from is the wrong word, its his company
Old    Bill Bierbower (monstertower)      Join Date: Mar 2003       10-09-2005, 8:24 AM Reply
Check out www.diytower.com
Old    Richard (ramhouse)      Join Date: Apr 2004       10-09-2005, 7:35 PM Reply
Depends on what hardware you need. I found and old swoop without the legs. I built them of 2" stainless. If you plan on lowering it, most can be found at an industrial hardware supplier. Don't even waste your time at Home Depot.
Old    bullet_tower            10-31-2005, 7:30 AM Reply
1 1/2 sch 40 pipe 6063 alloy, would be the norm in the 2" range (1.875 O.D. 1.61 I.D.) you will find more available fittings with that size Pipe. bullettower.com also sells fittings and they are made in USA baby!
Old    srxboy            11-02-2005, 8:23 AM Reply
what type of bender do i need to bend that? Can I use a pipe bender or do I need to drop the money for a tubing bender? Thanks for the great info!
Old    bullet_tower            11-03-2005, 6:48 AM Reply
pipe bender should work get one with the largest centerline radius posible. It will put less stress on the material
