Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through October 30, 2005
Old    David (liquidmarcus)      Join Date: May 2004       09-25-2005, 5:07 PM Reply
My friend just got a board/binding combo that was about $230. The board is white and blue with a dragon like thing on it. The bindigs are lace-up, mostly white with blue. The footbed is white also. Any ideas? He says the board is an Epic, but I can't find any Liquid Force board called the Epic. Any help is appreciated.
Old    260searay            09-25-2005, 5:47 PM Reply
The hyperlite motive has a dragon on it.
Old    David (liquidmarcus)      Join Date: May 2004       09-25-2005, 6:21 PM Reply
true, but I'm almost positive it's LF
Old    dahui            09-25-2005, 6:23 PM Reply
Bindings maybe hyperlite spin.
http://www.wakeworld.com/boots/getboot5.asp?ProductID=2120
Old    Blair (twitch)      Join Date: Dec 2004       09-25-2005, 6:41 PM Reply
sounds like the motive
http://www.wakeworld.com/boardguide/getboard5.asp?ProductID=2087
Old    Justin (wakesk8er2)      Join Date: Mar 2002       09-25-2005, 9:34 PM Reply
If he got it from a big chain store it might not be one that you will be able to find in any of the catalogs. Companies press boards specifically for the chains. You might have look at the shape/specs of the board and then do some research and find out what it is. If you look around, you can find some high end boards really cheap because of this, they will just have some crappy bindings on them.
Old    David (liquidmarcus)      Join Date: May 2004       09-26-2005, 2:09 PM Reply
Ok I gotcha, Justin I think youre right.
