Old    Midwestwakeboarder.com (mjmurphy53711)      Join Date: Mar 2004       09-12-2005, 6:39 PM Reply
okay, i have regular hs fs threes. Regarding switch I couldnt figure out whether to try a switch three or five, so i just went for it. The backside element of the pass is a lot easier for me than regular front side three's and I got the handle consistently, the only problam was I regularly landed switch heelside 450's today. Which should I concentrate on, sw hs threes or sw hs fives.....five seems easier if i can just get it around a bit more.
www.wakecoupons.com
Old    Christopher Stack (deepstructure)      Join Date: Jun 2002       09-12-2005, 7:17 PM Reply
i have yet to land any kind of 5, but i can do regular, and sometimes switch hs 3s. i wouldn't skip the switch 3. perhaps with ts spins the 5 is easier, but i haven't heard anyone say that about hs spins, regular or switch.
i would also think you weren't getting the final handle pass if you were landing 450s. concentrate on getting your 3s solid, then go for the 5s. actually then go for grabbed 3s, then the 5s. :-)
this sport is all about progression.
Old    Thane Dogg (thane_dogg)      Join Date: Jun 2002       09-12-2005, 7:22 PM Reply
then learn a tsbs 3, then you could get the switch hs 5 no problem.
Old    C.I.E..... Evan (guido)      Join Date: Jul 2002       09-13-2005, 1:09 PM Reply
the handle pass for tsbs 3's are a serious biatch.
Old    Christopher Stack (deepstructure)      Join Date: Jun 2002       09-14-2005, 1:20 AM Reply
sheesh - does everyone want to blow off progression around here?? :-) how 'bout tsbs180's first?
although something tells me more people get switch 5s before they can do bs ts 3s...
Old    David D (wakeguru)      Join Date: Feb 2003       09-14-2005, 7:22 AM Reply
Fives probably seem easier because you land front - I say go for the five. Practice on the trampoline w/handle to try and stick the last half of the rotation.
Old    Midwestwakeboarder.com (mjmurphy53711)      Join Date: Mar 2004       09-14-2005, 6:39 PM Reply
ha, thanks for the advice.....but i cant jump toeside. I know, lame right? Used to have it, lost it, cant get it back. Regarding the switch heel fives.......im going to land one next time out, ill report back.
Old    Delta Force (wakebordr11)      Join Date: May 2001       09-14-2005, 8:25 PM Reply
well since the landing of a switch hs 5 is going to be the same as a regular toeside jump, maybe you should work on landing toeside, then landing sw hs 5 would be a little easier...
fundamentals??? anyone?
Old    Thane Dogg (thane_dogg)      Join Date: Jun 2002       09-14-2005, 8:48 PM Reply
get on the tramp and do switch heel 7's, that will help.
Oh, and learn something toeside for the sake of skurfing.
Old    blind5            09-14-2005, 9:09 PM Reply
keep your handle in
Old    Midwestwakeboarder.com (mjmurphy53711)      Join Date: Mar 2004       09-14-2005, 9:41 PM Reply
rob i hadnt thought of that.....i think that might be what slows my rotation down. im passing the handle no problem but it is a few inches off my back....im going riding either tomorrow or friday, ill report back.
Old    Scot M Berner (scottyb)      Join Date: Sep 2002       09-15-2005, 2:10 PM Reply
Ride on a nautique!!!
Old    Kevin Bird (kevin_bird)      Join Date: Dec 2002       09-15-2005, 3:08 PM Reply
personally i would leartn a regular heelside bs 180 once that is down then toeside bs 180 then that switch three can be dialed in from there. Once that three is dialed it will make those fives alot more stylish and slow. the reason for the backside 180's is tht it is the same rotation as the last 180 in your swithc hs 360
Old    Midwestwakeboarder.com (mjmurphy53711)      Join Date: Mar 2004       09-15-2005, 5:28 PM Reply
ha. scot, last time i tried a new trick behind your nautique i broke a rib. that said, im in....friday am or anytime this weekend give me a call.
Old    natxbrotha            09-15-2005, 8:14 PM Reply
a switch hs 5 is made up of a ts bs 180, switch hs 360, and a switch hs 180. you can practice those on the surface to get comfortable at first. doing big super late 180s helps the ending of the trick. landing your switch hs 3's with both hands on the handle helps as well. pitching over a little helps too. you can learn this off the roller on the turn around, 1 wake, inside out, then w2w. i would imagine if you couldnt do a switch hs 360, then the switch hs 540 is going to be a little out of reach. but by all means, if you can get the handle passes no problem and stay on axis, go for it.
Old    Midwestwakeboarder.com (mjmurphy53711)      Join Date: Mar 2004       09-15-2005, 9:29 PM Reply
kevin ive had my heeside backsides down for awhile now. This post can chill for a bit, ive got to get back out there and see what happens.
Old    Midwestwakeboarder.com (mjmurphy53711)      Join Date: Mar 2004       09-16-2005, 9:48 PM Reply
got back out today and no dice. I did land a switch 3 though.....I think I better dial those in first. That second pass is a B**ch even if the rotation feels more natural, thanks for all the advice peeps.
www.wakecoupons.com
Old    Christopher Stack (deepstructure)      Join Date: Jun 2002       09-17-2005, 12:45 AM Reply
congrats on the switch 3 - that's no mean feat in itself! now go work on your ts edge! ;)
Old    Scot M Berner (scottyb)      Join Date: Sep 2002       09-18-2005, 12:04 PM Reply
Sweet that is awesome mike, big props. I am just giving ya crap about the nautique buisness, I am just getting back on the water I ride at like 55' feet now so I can jump and its easier on my knee. But we should hook up and ride soon.
Old    Gordon M (gmarkham1)      Join Date: Sep 2003       09-19-2005, 7:40 AM Reply
Scott,
I am off this friday, you all should trailer the boat down to the river! Or just come out and ride with me!
